UCTRONIC -
B0205 (?) -
Raspberry Pi 3 b + -
GOOGLE for days… -
IR Filter does not react at all. At startup, it moves then dead. Independent on light situation, OS, USB port, PC. Infrared LED work fine. -
na -
GOOGLE for days
As the Board is not similar to the one in Pi Camera Modules with Switchable IR-cut Filter - Arducam I can not use this description.
Check for software solution not viable because option / flag for IR Filter is not known -
How can I make it work (via OpenCV option, hardware soldering, etc).
