Temu -
Not quite sure as I can’t find one -
Pi 4 with klipper installed -
Not many as not much available for this problem -
It seems to be permanently on ir mode. I tried adding disable_camera_led=1 to config.txt, rebooted, and it seemed to auto switch a couple times on boot up, and then stays in ir mode. Not sure if it’s a klipper issue, or a pi setting or what.
I reboot, it’s in non ir mode, I turn my lights off to trigger it, turn them back on, and it doesn’t change, gets stuck in IR mode. -
Removed one IR light, rebooted, addud disable_camera_led=1 -
Figuring out why it gets stuck in IR mode
Can you post the link where you buy this camera?
Any ideas? Not finding many answers anywhere else.
I can not figure out what you mean, may you explain it more thoroughly? I have completely been confused by your description ![]()
So, the ir cut seems like it works. I’m using klipper for 3d printing. So I turn the pi on, it boots up, I can see the image on the dashboard, and it looks normal. I turn the lights off to trigger the ircut, it triggers, but then it stays like that. The ir filter won’t turn back off. Or the lights.
