That’s good to hear. By the way, we can also prepare a QC checklist for your quality inspections if that would help — just let me know and we’ll put one together.
Quick question — when I view the B0579 image through VLC, it looks compressed or kind of blurry. Is this possibly a driver-related issue on our side, or something with the module itself?
No, I haven’t refocused the lens. Here’s a quick SFR comparison between the two models:
B0579: SFR = 25% (looks blurry/compressed)
B0547: SFR = 47%
So there’s a pretty big difference. Also, I’m seeing another issue — when I operate the B0579 on the NX by itself, I just get a green screen. But if I connect a second camera and run both simultaneously, the Arducam camera starts working. That’s odd, right?
Our engineer has optimized the firmware and is preparing update instructions — I’ll send those your way via private message once they’re ready.
Regarding the green screen: a solid green image typically means no data is being received at all. I also notice you’re using a third-party Forcer carrier board, which makes root-cause analysis trickier. Could you capture a video of the green screen behavior and share it? I’ll forward it to our engineering team.
Here’s another detail on the green screen — if I just wait about 1 minute and then try operating the camera again, it works. So it’s like it needs a warm-up or retry period. Any idea why that would happen?
Quick update: we’ve now got 18 of the new B0579 modules and pretty much all of them are showing the green screen (no data). It takes several attempts before an image stream finally appears. So far we’ve only been able to test about 2 of the 18 properly. Also, do you have a driver available for the AGX platform? We’d like to test there as well.
On the green screen issue: that symptom — no data received — normally only shows up when the camera is connecting over a 2-lane interface. Since you’re on the third-party Forcer carrier board, could you try testing the B0579 on a standard Nvidia Jetson carrier board (the official developer kit) instead? That would help narrow things down significantly.
As for AGX: the B0579 doesn’t natively support the AGX platform. If you need AGX compatibility, some adaptation work would be required.
On our end, we’ve tested the B0579 in super mode on the official Jetson developer kit and it works without issues there.
The green screen is intermittent — I ran the pipeline twice back to back. First attempt failed to show any video, second attempt succeeded. I’ve attached the logs from both runs. Can your team take a look?
I’ve reviewed the logs you shared. The behavior is definitely inconsistent — the failures are intermittent, which makes this tricky to pin down.
One thing I want to flag: since you’re running on the third-party Forcer carrier board, our drivers and hardware compatibility are strictly verified against the official Nvidia Developer Kit (reference design). Debugging on custom or third-party carrier boards is difficult because there can be variations in:
Pin definitions
Signal timing
Power delivery design
These kinds of discrepancies often produce exactly the logs you’re seeing.
Take one of the B0579 cameras and test it on an official Nvidia Jetson Developer Kit carrier board.
Run the same pipeline and see if the green screen issue reproduces.
If the problem persists on the official board, we’ll treat this as a bug on our side and dig into the logs to fix it.
If the camera works fine on the official board, then the issue is likely specific to the Forcer carrier board’s design, and you may need to review that with the carrier board vendor.
Please run that test and let us know the results — that’ll determine the next steps.
