Install_full.sh invalid arithmetic operator error on Jetson AGX Orin
Hey everyone, I’m running into an issue trying to install the Arducam USB camera drivers on my Jetson AGX Orin Developer Kit. I have three AR0234 USB 3.0 cameras connected.
When I run the install script:
./install_full.sh
It immediately bombs out with this error:
./install_full.sh: line 126: 5.15.148-tegra-36.4.3-20250107174145: syntax error: invalid arithmetic operator
Looks like something on line 126 is choking on the kernel version string. My setup is JetPack 6.2, L4T 36.4.3, kernel 5.15.148-tegra-36.4.3-20250107174145.
Anyone else seen this? Is there a workaround?
Thanks for the detailed report. That kernel version string is definitely the culprit here.
Just to confirm — can you share the output of:
uname -r
Also, could you post the exact camera module model you’re using? There are a few AR0234 variants and I want to make sure we point you at the right resources.
Sure, here’s the kernel info:
$ uname -r
Running JetPack 6.2 on the AGX Orin Dev Kit as mentioned. I’m using three of these cameras: https://www.uctronics.com/arducam-2-3mp-ar0234-color-global-shutter-usb-3-0-camera-module.html
I did try a quick-and-dirty workaround. I edited the script manually and replaced the kernel version string so it only reads 5.15.148 instead of the full Jetson string. That got me past line 126. But then the script couldn’t find any matching .deb package for that kernel version — it just fails later on when it tries to locate the kernel patch.
Here are screenshots of what I’m seeing:
error screenshot
package not found
So hacking the version string isn’t really getting me anywhere.
Thanks for the screenshots and the details — that helps a lot.
Here’s what’s happening:
Root cause: Line 126 of install_full.sh is performing an arithmetic evaluation on the full kernel version string. The Jetson kernel version includes hyphens and alphanumeric characters (-tegra-36.4.3-20250107174145), which bash’s arithmetic parser can’t handle. The script doesn’t strip the Jetson-specific suffix before doing that operation.
The bigger issue: Even if you patch around the syntax error, there doesn’t appear to be a pre-built .deb kernel patch package available for kernel 5.15.148-tegra-36.4.3-20250107174145 (which is the JetPack 6.2 / L4T 36.4.3 kernel). So the script failing to find a matching package after you normalize the version is expected.
In the meantime, your best starting point for getting the cameras operational is the Linux Quick Start Guide here: Start USB3 UVC Camera on Linux - Arducam Wiki
That guide covers UVC camera usage without necessarily needing the kernel patch, depending on what features you need.
Got it, that makes sense. So line 126 needs to be patched to properly extract just the numeric portion of the kernel version before doing any arithmetic — something like stripping everything after the first hyphen in the version string.
I’ll go through the Quick Start Guide you linked. But just to be clear — is JetPack 6.2 officially supported yet? Am I going to be blocked on getting the full driver stack working until a new kernel patch package is released for L4T 36.4.3?
You’ve nailed the fix needed on the script side — isolating just the numeric kernel version (e.g., 5.15.148) from the full Jetson string before any arithmetic operations on line 126. The script needs to handle extended Jetson kernel suffixes like -tegra-36.4.3-20250107174145.
As for JetPack 6.2 support: at this point it’s not yet confirmed whether JetPack 6.2 / L4T 36.4.3 is officially supported or when a compatible kernel patch package will be released. That’s the pending item on our side. The Quick Start Guide should get you basic UVC functionality in the meantime — you may not need the kernel patch at all depending on your use case (the patch is primarily for certain advanced features like multi-camera sync or custom controls).
Give the guide a shot and let us know how far you get. I’ll also flag the install_full.sh parsing issue so the team can get that fixed for future Jetson releases.
