I am trying to get an IMX298 (16MP) ArduCAM to run on a new Raspberry Pi 4B 8GB. I followed the instructions on the ArduCAM website initially and then re-ran the installation with the additional steps set out for the Pi 4B on the GitHub website. I keep getting a message as follows:
Open camera…
init camera status = 4099.
I cannot find any information on what the 4099 status means or what could be preventing the camera from initialising. I’m not sure whether it’s something I’m doing wrong or whether it’s a compatibility issue with the new 8GB Raspberry Pi. Any help would be appreciated.
Thank you for helping. I have tried your suggestion but only receive a message “command not found”. I also tried running it as sudo but no luck with that either. I can see camera_i2c in the utils sub-directory and have checked that i2c is enabled in the Raspberry Pi configuration settings but it doesn’t run.
Please let me know if you need any other details, as I’m not sure what you need from the terminal information.
Thank you. I tried this and still had the same issue.
I have since tested the camera on a Pi Zero W and it worked fine after I installed the software according to the instructions. I have reinstalled all the software for the Pi 4B 8GB but still have the same problem.
Hi, I have the same issue with RPi4 8GB on Arducam OV9281. It worked fine on RPi4 4GB and but on RPi8GB I’m getting “init camera status = 4099” even after clean reinstallation and so on. Have you tested it on RPI4 8GB?
