Incorrect values read when trying to get a JPEG
    Two identical cameras from Arducam web site
    3MP-NoIR 10th anniversary edition, SKU B0435
    Custom board with ATmega32U4, 8 MHz SPI
    Mega SPI Camera Series Application Note (very incomplete, registers missing), source code from Arducam’s GitHub (mainly ArducamCamera.c)
  5. Problems you were having?
    Trying to get a JPEG I get always the same absurd size (8390520, greater than 8 MB), and the data is not a valid JPEG.
  6. What help do you need?
    Proper register table for this camera, point if something is missing in my code
    I will read later also raw RGB values (format 2): How are these values returned, RGB565? Little endian or big endian?
My code:
// Init camera
SingleWrite(CAM_REG_SENSOR_RESET, CAM_SENSOR_RESET_ENABLE_MASK); // 0x07, (1 << 6)
SingleWrite(CAM_REG_FORMAT, FORMAT_JPEG); // 0x20, 1
SingleWrite(CAM_REG_IMAGE_QUALITY, JPEG_QUALITY_LOW); // 0x2A, 2
SingleWrite(CAM_REG_CAPTURE_RESOLUTION, RESOLUTION_1600X1200); // 0x21, 6
// Read some values, all OK
const uint8_t Sensor = SingleRead(CAM_REG_SENSOR_ID); // 0x40, returns 0x84 (3 Mp v2)
const uint8_t Year = SingleRead(CAM_REG_YEAR_ID); // 0x41, returns 23
const uint8_t Month = SingleRead(CAM_REG_MONTH_ID); // 0x42, returns 4
const uint8_t Day = SingleRead(CAM_REG_DAY_ID); // 0x43, returns 12
// Take snapshot
SingleWrite(CAM_REG_SENSOR_RESET, CAM_SENSOR_RESET_CLEAR_MASK); // 0x07, (1 << 7)
SingleWrite(CAM_REG_FIFO_CONTROL, FIFO_CONTROL_CLEAR_MASK); // 0x04, (1 << 0)
SingleWrite(CAM_REG_FIFO_CONTROL, FIFO_CONTROL_START_MASK); // 0x04, (1 << 1)
// Wait capture
while ((SingleRead(CAM_REG_SENSOR_STATE) & CAM_SENSOR_STATE_DONE_MASK) == 0); // 0x44, (1 << 2)
// Read data length
const uint32_t LengthLow = SingleRead(CAM_REG_FIFO_SIZE_LOW); // 0x45
const uint32_t LengthMid = SingleRead(CAM_REG_FIFO_SIZE_MID); // 0x46
const uint32_t LengthHigh = SingleRead(CAM_REG_FIFO_SIZE_HIGH); // 0x47
const uint32_t Length = LengthLow | (LengthMid << 8) | (LengthHigh << 16);
Surprise! Here Length is always 8390520 (0x800778), greater than the FIFO size (8 MB) and too big for a JPG.
When I read these bytes the content is not a JPEG. The first 48 bytes are:
D4 93 DC B4 DC D5 E4 F5 E4 F5 E5 15 E5 15 E5 15
E4 F5 E4 F5 E4 F5 EC F5 EC F5 ED 16 ED 15 ED 36
F5 57 F5 57 ED 56 ED 56 ED 57 F5 77 F5 77 F5 77
I found the problem: waiting for I2C completion is your friend, specially after changing image format.
IMHO the MEGA documentation (specially register list) is incomplete and poor.
Can you elaborate on your fix here? I have the same problem with the 5MP NoIR. The regular 5MP camera works fine, but I always get the length of 8390520 when using the NoIR version.
I’m not changing the format. I use the same format each time.
myCAM = new Arducam_Mega(CAM_CS);
myCAM->begin();
... LATER ...
myCAM->takePicture(CAPTURE_MODE, CAM_IMAGE_PIX_FMT_JPG);
Serial.printf("Total length: %lu\n", myCAM->getTotalLength());
I see there’s a waitI2cIdle in arducamcamera.c. Shouldn’t this cover the wait for me?
Thanks
Almost immediately solved my own problem. It seems this camera doesn’t support the same capture resolutions as the regular 5MP. If you set CAM_IMAGE_MODE_WQXGA2 then it works
