Imx708: probe of 10-001a failed with error -121
    Ans. Amazon.com
    Ans. B0484 (Arducam 12MP IMX708 Quad-Camera Module)
    Ans. Nvidia Jetson Orin Nano (Jetpack 6.1 - 5.15.148-tegra)
    https://docs.arducam.com/Nvidia-Jetson-Camera/Native-Camera/Quick-Start-Guide/#1-hardware-connection
  5. Problems you were having?
    Whenever tried to run to perform stream from the Camera module attached at CAM1 of the Jetson Orin Nano using following script,
    SENSOR_ID=1
    FRAMERATE=30
    gst-launch-1.0 nvarguscamerasrc sensor_id=$SENSOR_ID ! “video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1,format=NV12” ! nvvidconv flip-method=0 ! “video/x-raw,width=960,height=720” ! nvvidconv ! nvegltransform ! nveglglessink -e
    getting following error at terminal window before having gst-launch window terminated,
    Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:797 Invalid camera device specified 1 specified, 0 max index
    Redistribute latency…
    WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
    "[ 10.629078] imx708 9-001a: tegracam sensor driver:imx708_v2.0.6
    [ 10.929757] imx708 9-001a: imx708_board_setup: invalid sensor model id: 77
    [ 10.930412] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx708 9-001a bound
    [ 10.935754] imx708 10-001a: tegracam sensor driver:imx708_v2.0.6
    [ 11.238606] imx708 10-001a: imx708_board_setup: error during i2c read probe (-121)
    [ 11.238644] imx708 10-001a: board setup failed
    [ 11.238740] imx708: probe of 10-001a failed with error -121
    Ans. “#31-camera-not-found” troubleshooting guide from Arducam Wiki
  8. What help do you need?
    Ans. Need help in troubleshooting issue facing with use of Single Camera module from Quad Kit and if possible integrate Quad Kit of 12MP IXM708 in the Jetson Orin Nano.
Thanks for providing the detailed system information and error logs.
There are two important points to clarify regarding the B0484 IMX708 Quad-Camera Kit.
1. Using an individual IMX708 module directly on Jetson
The IMX708 camera modules included in the B0484 kit are designed to work with the CamArray HAT. Unlike standard standalone IMX708 camera modules, these modules do not have their own onboard clock oscillator.
They rely on the clock signal supplied by the CamArray HAT to operate correctly.
Therefore, an individual camera module from the B0484 kit cannot be connected directly to a Raspberry Pi or Jetson CSI port.
This also explains why the camera cannot initialize properly in your current setup.
2. B0484 Quad-Camera Kit compatibility with Jetson Orin Nano
Unfortunately, the B0484 Quad-Camera Kit is currently supported only on Raspberry Pi platforms.
We have not developed a corresponding Jetson driver for this kit, so connecting the complete B0484 kit through its CamArray HAT to the Jetson Orin Nano is also not supported.
If you would like to continue using the B0484, we recommend using it with a supported Raspberry Pi platform.
