Where did you get the camera module(s)? Amazon
Model number of the product(s)? - 120° IMX708 Manual Focus Pi Camera V3 with M12 Lens
What hardware/platform were you working on? - Raspberry Pi 5
Instructions you have followed. (link/manual/etc.) ChatGPT
Problems you were having? camera not being detected
I’m using the Arducam IMX708 Manual Focus Camera V3 (M12, 120° Wide) on Raspberry Pi 5, Bookworm OS.
I’ve correctly configured dtoverlay=arducam-pivariety,cam0 in /boot/firmware/config.txt, installed the Pivariety drivers, and verified the ribbon cable and slot (CAM0).
However, the camera fails to respond. Logs show:
dmesg → arducam-pivariety 6-000c: probe failed
i2cdetect -y 6 → no device detected
libcamera → no cameras found
The OV5647 works fine on the same Pi and slot. Can you confirm if this model works with Pi 5 and Bookworm? Or is it a hardware issue?
