Hi everyone, I’m trying to get an IMX708 camera working on my Jetson Nano using a Seeed Studio carrier board. When I run the camera setup/install script it fails with this error: “Cannot find the corresponding deb package, please send the following information to [email protected]”. I’m not sure what I’m missing here. Has anyone run into this before?
Could you share your kernel version and the exact Jetson type? You can get the kernel version with uname -r, and the Jetson type should be shown by the board info tool (or it’s printed on the kit itself).
Sure. Kernel version is 4.9.337-tegra-32.7.4-20230608212426 and the Jetson type shows as NVIDIA Jetson Nano Developer Kit.
Thanks. Just to narrow things down - are you running any custom code, or just following the standard camera setup steps? And what have you tried so far besides running the installer?
No custom code on my side, I’m just trying to install the camera driver following the usual guide. I haven’t really done anything beyond that yet. Is there an extra step I’m supposed to do on the Seeed carrier board side? Any advice on what else I should check?
Looking at your kernel version, I think I see the problem. 4.9.337-tegra-32.7.4 corresponds to L4T 32.7.4, and Arducam hasn’t released the camera driver for that L4T version yet. The installer can’t find a matching deb package, which is exactly the error you’re seeing. The driver is version-specific - if your L4T/JetPack version isn’t in the supported list, there won’t be a matching package to download.
Ah, that makes sense. So what should I do from here? Do I need to downgrade the system or something?
The fix is to reflash your Nano with a JetPack version that’s on the supported list. You can check the supported versions here: Introduction to Arducam Jetson Cameras - Arducam Wiki and burn one of those to your SD card. After that, the installer should find the correct package for the IMX708. In short: the current conclusion is that L4T 32.7.4 has no matching Arducam driver package yet, so stick to a JetPack version from the supported list.
