Hello guys!
I’m having the following problem and I hope you have any clue about what’s happening. The device I have is an Arducam 16Mpx (IMX519) from Kickstarter campaign, using a Raspberry PI3B.
First of all, these are my outputs:
uname -a
Linux krvkweather 5.15.61-v7+ #1579 SMP Fri Aug 26 11:10:59 BST 2022 armv7l GNU/Linux
cat /etc/os-release
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
cat /proc/meminfo
MemTotal: 944268 kB
MemFree: 685824 kB
MemAvailable: 806184 kB
Buffers: 35536 kB
Cached: 123500 kB
SwapCached: 0 kB
Active: 95192 kB
Inactive: 112092 kB
Active(anon): 756 kB
Inactive(anon): 48540 kB
Active(file): 94436 kB
Inactive(file): 63552 kB
Unevictable: 16 kB
Mlocked: 16 kB
SwapTotal: 102396 kB
SwapFree: 102396 kB
Dirty: 52 kB
Writeback: 0 kB
AnonPages: 48308 kB
Mapped: 41804 kB
Shmem: 1024 kB
KReclaimable: 14856 kB
Slab: 30452 kB
SReclaimable: 14856 kB
SUnreclaim: 15596 kB
KernelStack: 1168 kB
PageTables: 1440 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 574528 kB
Committed_AS: 280188 kB
VmallocTotal: 1114112 kB
VmallocUsed: 5812 kB
VmallocChunk: 0 kB
Percpu: 400 kB
CmaTotal: 262144 kB
CmaFree: 258264 kB
cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
#dtoverlay=arducam-pivariety
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=imx519
dtparam=i2c1=on
dtoverlay=pi3-miniuart-bt
dtoverlay=miniuart-bt
core_freq=250
./install_pivariety_pkgs.sh -l
Hardware Revision: a02082
Kernel Version: 5.15.61-v7+
OS Codename: bullseye
ARCH: armv7l
libcamera-hello --list-cameras
Available cameras
0 : imx519 [4656x3496] (/base/soc/i2c0mux/[email protected]/[email protected])
Modes: 'SRGGB10_CSI2P' : 1280x720 [120.02 fps - (1048, 1042)/2560x1440 crop]
1920x1080 [60.00 fps - (408, 674)/3840x2160 crop]
2328x1748 [30.00 fps - (0, 0)/4656x3496 crop]
3840x2160 [21.01 fps - (408, 672)/3840x2160 crop]
4656x3496 [10.00 fps - (0, 0)/4656x3496 crop]
What’s the problem?
I’m running a Telegram bot that takes photos on demand with the following command:
/usr/bin/libcamera-still -n --autofocus-on-capture -o test.jpg
Sometimes photos are as expected, nice; but sometimes it takes photos like the second one:
I’m trying also to perform a timelapse (2 photos per minute during 1 hour) and this is the result: timelapse - YouTube
I updated yesterday the pivariety_pkgs and reinstalled imx519_slow_driver, libcamera and libcamera_dev.
I’m afraid to move to a newer libs/kernel/distro version.
If you need further information, do not hesitate to request it.
Thanks in advance.
