Hi all. I have an Arducam IMX519 NOIR camera on a Jetson Nano 4GB dev kit and it has never worked since I got it. I followed the Arducam native camera guide for the IMX519 at 16MP IMX519 - Arducam Wiki and also tried a RidgeRun kernel rebuild, but after the RidgeRun rebuild the board wouldn’t even boot. I reflashed and started over, tried JetPack 4.6 through 4.6.4, and the driver install keeps failing with ‘Errors were encountered while processing: arducam-nvidia-l4t-kernel’ and ‘An unknown error occurred while installing dtoverlays.’ Is there a correct driver for JetPack 4.6.4 on the Nano?
Thanks for the details. Can you confirm the exact JetPack version you’re on right now and paste the full terminal output from the driver installation? The dtoverlay error plus the package processing error usually means the post-installation script is failing partway through, but the full log will show the actual command that’s dying.
Right now I’m on JetPack 4.6.4, but I’ve also tried 4.6, 4.6.1, and 4.6.2 after reflashing. Same result each time. The errors are: dpkg: error processing package arducam-nvidia-l4t-kernel (–install): Installed arducam-nvidia-l4t-kernel package post-installation script subprocess returned exit status 255 Errors were encountered while processing: arducam-nvidia-l4t-kernel. Plus the ‘unknown error occurred while installing dtoverlays’ line.
That’s helpful. Exit status 255 from the post-installation script indicates the script is failing while trying to install the device tree overlays, which is why dpkg reports the package as failed. I still need the complete error log from the install command though—the summary lines don’t show what’s underneath. Could you run the install again and paste the whole output?
Here’s what I get: ‘An unknown error occurred while installing dtoverlays.’ then ‘dpkg: error processing package arducam-nvidia-l4t-kernel (–install):’ ‘Installed arducam-nvidia-l4t-kernel package post-installation script subprocess returned exit status 255’ ‘Errors were encountered while processing:’ ‘arducam-nvidia-l4t-kernel’. That’s basically all it prints aside from the normal dpkg output.
OK, so the failure point is confirmed: the arducam-nvidia-l4t-kernel post-installation script is failing at the dtoverlay installation step and returning exit status 255, which makes dpkg mark the package as failed. It’s still unresolved—I’d need the full/complete error log from the installation to see the exact dtoverlay command that’s failing. In the meantime, make sure you’re following the quick start steps for the 16MP IMX519 camera on the Arducam docs, and if you can capture the entire terminal output from the install command (not just the dpkg summary), that will help us get to the actual overlay failure.
