IMX519 MJPEG Encoder
    From Arducam China
    16MP IMX519
    Raspberry Pi 4b / 64-bit Pi OS Lite bookworm
  5. Problems you were having?
I have an Arducam 16MP IMX519 camera, and I am able to capture images at the highest resolution using the mjpeg codec through the command line:
libcamera-vid -n --codec mjpeg -t 10000 --segment 1 -o test_%04d.jpg --width 4656 --height 3496 --brightness 0.0 --contrast 1.0 --exposure normal --gain 3 --awb auto --metering centre --saturation 1.0 --sharpness 1.0 --denoise cdn_off --quality 95
with a frame rate of about 8-9 frames.
However, when I try to capture images using picamera2, I encounter an error. My code is as follows:
import time
import libcamera
from picamera2.encoders import H264Encoder,MJPEGEncoder
from libcamera import controls
picam2 = Picamera2()
video_config = picam2.create_video_configuration({“size”: (4656, 3496)})
picam2.configure(video_config)
picam2.set_controls({“AfMode”: controls.AfModeEnum.Continuous, “FrameRate”: 1})
encoder = MJPEGEncoder(10000000)
picam2.start_recording(encoder, ‘test.mjpeg’)
time.sleep(10)
picam2.stop_recording()
Error message:
dmesg
