Welectron -
Arducam B0389 -
Raspberry Pi 4 -
N/A -
I would like to adjust the lens to focus closer. -
N/A -
N/A -
Is it possible to un-thread the lens a bit to bring the focus closer to the module? I am trying to reach a focus distance of no more than 3cm.
You’d better not unthread the lens. This camera uses a stock lens that can not move the lens.
Thanks Dion. Are you saying the lense is not threaded? From the module pictures I have seen there are some very fine threads on the lense.
I’m sure it’s probably glued in place from the factory but so we’re my webcams I used for testing and I was able to remove the glue no issue.
What would be the risk?
The risk is that if you remove the lens, there is no warranty.
