Pimoroni -
IMX519 16MP Autofocus -
Raspberry P 4 -
Raspberry Pi libcamera Guide - Arducam -
What resolutions retain the original view angle / FoV?
Some resolutions appear to crop the center of the image (eg: 640x480). I would like a lower resolution, higher FPS version of the whole image. Is this possible? -
dmesg | grep arducam > there is no output
v4l2-ctl --list-formats-ext > 45 entries, along the lines of
[45]: 'Y14 ' (14-bit Greyscale)
Size: Stepwise 16x16 - 16376x16376 with step 1/1
[0:22:05.754269989] [2157] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3431-c4602118
[0:22:05.791487286] [2158] WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'imx519'
[0:22:05.791564563] [2158] WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[0:22:05.791675821] [2158] ERROR CameraSensor camera_sensor.cpp:551 'imx519 10-001a': Camera sensor does not support test pattern modes.
[0:22:05.811205560] [2158] WARN RPI raspberrypi.cpp:1233 Mismatch between Unicam and CamHelper for embedded data usage!
[0:22:05.812071938] [2158] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:22:05.812435563] [2158] INFO RPI raspberrypi.cpp:1356 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media0 and ISP device /dev/media1
Available cameras
0 : imx519 [4656x3496] (/base/soc/i2c0mux/i2c@1/imx519@1a)
Modes: 'SRGGB10_CSI2P' : 1280x720 1920x1080 2328x1748 3840x2160 4656x3496
Tried testing various resolutions. Some are cropped, some are not.
- What help do you need?
I would like to know what resolutions are not cropped, or how I can stop it from cropping. I am using:
libcamera-still -o libcam640x480.jpg --width 640 --height 480
libcamera-still -o libcam4656x3496.jpg --width 4656 --height 3496
etc, etc
