SWITCH SCIENCE -
IMX519 fixed focus camera module(NOIR) -
Raspberry Pi ModelB and Raspberry Pi 4 ModelB -
https://www.arducam.com/downloads/arducam-imx519-start-guide.pdf
How To Use Arducam 16MP Camera On Raspberry Pi - Arducam -
can’t detect camera
[ 7.647605] imx519: loading out-of-tree module taints kernel.
[ 7.928959] imx519 10-001a: failed to read chip id 519, with error -5
[ 8.068912] imx519: probe of 10-001a failed with error -5
[ 0.000000] Linux version 5.15.61-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 28 pages/cpu s77272 r8192 d29224 u114688
[ 0.000000] pcpu-alloc: s77272 r8192 d29224 u114688 alloc=28*4096
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1983488
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:3840x2160M@30 smsc95xx.macaddr=DC:A6:32:EE:C3:AB vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=e6c8ed2d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] software IO TLB: mapped [mem 0x0000000016c00000-0x000000001ac00000] (64MB)
[ 0.000000] Memory: 7488452K/8060928K available (11520K kernel code, 1956K rwdata, 4140K rodata, 3840K init, 974K bss, 244796K reserved, 327680K cma-reserved)
[ 0.000000] ftrace: allocating 38040 entries in 149 pages
[ 0.000000] ftrace: allocated 149 pages with 4 groups
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 10)
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000313] Console: colour dummy device 80x25
[ 0.000367] printk: console [tty1] enabled
[ 0.000442] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000469] pid_max: default: 32768 minimum: 301
[ 0.000600] LSM: Security Framework initializing
[ 0.000863] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000971] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002222] cgroup: Disabling memory control group subsystem
[ 0.004903] rcu: Hierarchical SRCU implementation.
[ 0.006017] EFI services will not be available.
[ 0.006539] smp: Bringing up secondary CPUs …
[ 0.007582] Detected PIPT I-cache on CPU1
[ 0.007663] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.008914] Detected PIPT I-cache on CPU2
[ 0.008966] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.010112] Detected PIPT I-cache on CPU3
[ 0.010163] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.010313] smp: Brought up 1 node, 4 CPUs
[ 0.010335] SMP: Total of 4 processors activated.
[ 0.010347] CPU features: detected: 32-bit EL0 Support
[ 0.010357] CPU features: detected: 32-bit EL1 Support
[ 0.010369] CPU features: detected: CRC32 instructions
[ 0.042880] CPU: All CPU(s) started at EL2
[ 0.042955] alternatives: patching kernel code
[ 0.044696] devtmpfs: initialized
[ 0.055716] Enabled cp15_barrier support
[ 0.055757] Enabled setend support
[ 0.055786] KASLR enabled
[ 0.055965] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.055997] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.065298] pinctrl core: initialized pinctrl subsystem
[ 0.066124] DMI not present or invalid.
[ 0.066825] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.070582] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.070892] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.071796] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.071899] audit: initializing netlink subsys (disabled)
[ 0.072216] audit: type=2000 audit(0.072:1): state=initialized audit_enabled=0 res=1
[ 0.072738] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.072953] cpuidle: using governor menu
[ 0.073322] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.073520] ASID allocator initialised with 32768 entries
[ 0.073673] Serial: AMBA PL011 UART driver
[ 0.087995] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.120377] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-08-26T14:03:16, variant start
[ 0.124396] raspberrypi-firmware soc:firmware: Firmware hash is 102f1e848393c2112206fadffaaf86db04e98326
[ 0.175784] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.180153] vgaarb: loaded
[ 0.180710] SCSI subsystem initialized
[ 0.180917] usbcore: registered new interface driver usbfs
[ 0.180977] usbcore: registered new interface driver hub
[ 0.181042] usbcore: registered new device driver usb
[ 0.181426] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.181617] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.181917] pps_core: LinuxPPS API ver. 1 registered
[ 0.181930] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.181951] PTP clock support registered
[ 0.183430] clocksource: Switched to clocksource arch_sys_counter
[ 0.271992] VFS: Disk quotas dquot_6.6.0
[ 0.272099] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.272265] FS-Cache: Loaded
[ 0.272501] CacheFiles: Loaded
[ 0.273864] simple-framebuffer 3e29a000.framebuffer: framebuffer at 0x3e29a000, 0x960000 bytes
[ 0.273885] simple-framebuffer 3e29a000.framebuffer: format=a8r8g8b8, mode=1920x1280x32, linelength=7680
[ 0.274406] Console: switching to colour frame buffer device 240x80
[ 0.287445] simple-framebuffer 3e29a000.framebuffer: fb0: simplefb registered!
[ 0.297773] NET: Registered PF_INET protocol family
[ 0.298665] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.304344] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.304431] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.304461] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.304885] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.305966] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.306236] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.306376] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.306776] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.307907] RPC: Registered named UNIX socket transport module.
[ 0.307926] RPC: Registered udp transport module.
[ 0.307937] RPC: Registered tcp transport module.
[ 0.307947] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.307967] PCI: CLS 0 bytes, default 64
[ 0.310790] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.311124] kvm [1]: IPA Size Limit: 44 bits
[ 0.312409] kvm [1]: vgic interrupt IRQ9
[ 0.312678] kvm [1]: Hyp mode initialized successfully
[ 1.108144] Initialise system trusted keyrings
[ 1.108530] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.115218] zbud: loaded
[ 1.117088] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.117751] NFS: Registering the id_resolver key type
[ 1.117796] Key type id_resolver registered
[ 1.117807] Key type id_legacy registered
[ 1.117912] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.117927] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.119108] Key type asymmetric registered
[ 1.119124] Asymmetric key parser ‘x509’ registered
[ 1.119205] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.119487] io scheduler mq-deadline registered
[ 1.119503] io scheduler kyber registered
[ 1.127909] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.127955] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.128040] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.128120] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff → 0x0400000000
[ 1.193541] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.193925] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.193942] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.193959] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.194044] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.194288] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.198173] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.198521] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.198643] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.199066] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.203063] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.203108] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.203130] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.203169] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.203189] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.214862] iproc-rng200 fe104000.rng: hwrng registered
[ 1.215358] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.216886] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.229377] brd: module loaded
[ 1.238968] loop: module loaded
[ 1.239836] Loading iSCSI transport class v2.0-870.
[ 1.244994] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.303572] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.304704] usbcore: registered new interface driver r8152
[ 1.304778] usbcore: registered new interface driver lan78xx
[ 1.304828] usbcore: registered new interface driver smsc95xx
[ 1.351584] pci 0000:00:00.0: enabling device (0000 → 0002)
[ 1.351771] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.351804] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.352593] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[ 1.353650] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.353672] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.353694] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.354117] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.354137] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.354152] usb usb1: Product: xHCI Host Controller
[ 1.354165] usb usb1: Manufacturer: Linux 5.15.61-v8+ xhci-hcd
[ 1.354178] usb usb1: SerialNumber: 0000:01:00.0
[ 1.354893] hub 1-0:1.0: USB hub found
[ 1.354964] hub 1-0:1.0: 1 port detected
[ 1.356011] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.356032] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.356046] usb usb2: Product: xHCI Host Controller
[ 1.356058] usb usb2: Manufacturer: Linux 5.15.61-v8+ xhci-hcd
[ 1.356071] usb usb2: SerialNumber: 0000:01:00.0
[ 1.356715] hub 2-0:1.0: USB hub found
[ 1.356810] hub 2-0:1.0: 4 ports detected
[ 1.358564] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.358901] dwc_otg: FIQ enabled
[ 1.358911] dwc_otg: NAK holdoff enabled
[ 1.358921] dwc_otg: FIQ split-transaction FSM enabled
[ 1.358934] Module dwc_common_port init
[ 1.359552] usbcore: registered new interface driver uas
[ 1.359663] usbcore: registered new interface driver usb-storage
[ 1.359874] mousedev: PS/2 mouse device common for all mice
[ 1.365775] sdhci: Secure Digital Host Controller Interface driver
[ 1.365796] sdhci: Copyright(c) Pierre Ossman
[ 1.366480] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.372371] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.372950] hid: raw HID events driver (C) Jiri Kosina
[ 1.373111] usbcore: registered new interface driver usbhid
[ 1.373124] usbhid: USB HID core driver
[ 1.373440] ashmem: initialized
[ 1.382088] NET: Registered PF_PACKET protocol family
[ 1.382223] Key type dns_resolver registered
[ 1.383525] registered taskstats version 1
[ 1.383563] Loading compiled-in X.509 certificates
[ 1.384243] Key type ._fscrypt registered
[ 1.384258] Key type .fscrypt registered
[ 1.384269] Key type fscrypt-provisioning registered
[ 1.396231] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.396524] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.396698] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
[ 1.405560] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.406037] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.407197] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.407217] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.437999] of_cfs_init
[ 1.438167] of_cfs_init: OK
[ 1.472694] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.473051] Waiting for root device PARTUUID=e6c8ed2d-02…
[ 1.529932] mmc1: new high speed SDIO card at address 0001
[ 1.607471] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.677472] mmc0: new ultra high speed DDR50 SDHC card at address 13ab
[ 1.678458] mmcblk0: mmc0:13ab SE032 28.8 GiB
[ 1.682243] mmcblk0: p1 p2
[ 1.682810] mmcblk0: mmc0:13ab SE032 28.8 GiB
[ 1.706070] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.706180] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.706776] devtmpfs: mounted
[ 1.714754] Freeing unused kernel memory: 3840K
[ 1.714973] Run /sbin/init as init process
[ 1.714984] with arguments:
[ 1.714993] /sbin/init
[ 1.715002] splash
[ 1.715011] with environment:
[ 1.715020] HOME=/
[ 1.715029] TERM=linux
[ 1.762107] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.762142] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.762158] usb 1-1: Product: USB2.0 Hub
[ 1.764536] hub 1-1:1.0: USB hub found
[ 1.764791] hub 1-1:1.0: 4 ports detected
[ 2.039189] systemd[1]: System time before build time, advancing clock.
[ 2.063493] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
[ 2.172098] usb 1-1.1: New USB device found, idVendor=0472, idProduct=0065, bcdDevice= 1.00
[ 2.172138] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.172154] usb 1-1.1: Product: Generic USB Hub
[ 2.172167] usb 1-1.1: Manufacturer: Chicony
[ 2.174737] hub 1-1.1:1.0: USB hub found
[ 2.177842] hub 1-1.1:1.0: 3 ports detected
[ 2.225596] NET: Registered PF_INET6 protocol family
[ 2.227490] Segment Routing with IPv6
[ 2.227534] In-situ OAM (IOAM) with IPv6
[ 2.297124] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.298091] systemd[1]: Detected architecture arm64.
[ 2.301940] systemd[1]: Set hostname to .
[ 2.475567] usb 1-1.1.1: new full-speed USB device number 4 using xhci_hcd
[ 2.597162] usb 1-1.1.1: New USB device found, idVendor=0472, idProduct=0065, bcdDevice= 1.00
[ 2.597202] usb 1-1.1.1: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[ 2.597218] usb 1-1.1.1: Product: PFU-65 USB Keyboard
[ 2.597232] usb 1-1.1.1: Manufacturer: Chicony
[ 2.609805] input: Chicony PFU-65 USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.0/0003:0472:0065.0001/input/input0
[ 2.668454] hid-generic 0003:0472:0065.0001: input,hidraw0: USB HID v1.00 Keyboard [Chicony PFU-65 USB Keyboard] on usb-0000:01:00.0-1.1.1/input0
[ 2.849590] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 2.903555] usb 1-1.1.2: new full-speed USB device number 5 using xhci_hcd
[ 2.984024] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.989007] systemd[1]: Created slice system-getty.slice.
[ 2.990301] systemd[1]: Created slice system-modprobe.slice.
[ 2.991255] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.992083] systemd[1]: Created slice User and Session Slice.
[ 2.992598] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.993701] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.994149] systemd[1]: Reached target Slices.
[ 2.994280] systemd[1]: Reached target Swap.
[ 2.998147] systemd[1]: Listening on Syslog Socket.
[ 2.998948] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.999334] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.000709] systemd[1]: Listening on Journal Audit Socket.
[ 3.001508] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.002507] systemd[1]: Listening on Journal Socket.
[ 3.006490] systemd[1]: Listening on udev Control Socket.
[ 3.007354] systemd[1]: Listening on udev Kernel Socket.
[ 3.008481] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.012707] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.017035] systemd[1]: Mounting RPC Pipe File System…
[ 3.018131] usb 1-1.1.2: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 3.018165] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.018182] usb 1-1.1.2: Product: USB Receiver
[ 3.018195] usb 1-1.1.2: Manufacturer: Logitech
[ 3.022671] systemd[1]: Mounting Kernel Debug File System…
[ 3.028074] systemd[1]: Mounting Kernel Trace File System…
[ 3.028608] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.035236] systemd[1]: Starting Restore / save the current clock…
[ 3.035510] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/0003:046D:C534.0002/input/input1
[ 3.040530] systemd[1]: Starting Set the console keyboard layout…
[ 3.046005] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.051647] systemd[1]: Starting Load Kernel Module configfs…
[ 3.057474] systemd[1]: Starting Load Kernel Module drm…
[ 3.076602] systemd[1]: Starting Load Kernel Module fuse…
[ 3.093142] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.096919] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1.2/input0
[ 3.103332] systemd[1]: Starting File System Check on Root Device…
[ 3.109872] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:046D:C534.0003/input/input2
[ 3.110547] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:046D:C534.0003/input/input3
[ 3.113485] systemd[1]: Starting Journal Service…
[ 3.121225] systemd[1]: Starting Load Kernel Modules…
[ 3.135922] fuse: init (API version 7.34)
[ 3.140170] systemd[1]: Starting Coldplug All udev Devices…
[ 3.168072] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:046D:C534.0003/input/input4
[ 3.168817] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.168985] hid-generic 0003:046D:C534.0003: input,hiddev96,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1.2/input1
[ 3.169920] systemd[1]: Mounted RPC Pipe File System.
[ 3.171000] systemd[1]: Mounted Kernel Debug File System.
[ 3.171851] systemd[1]: Mounted Kernel Trace File System.
[ 3.173948] systemd[1]: Finished Restore / save the current clock.
[ 3.176741] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.179265] systemd[1]: [email protected]: Succeeded.
[ 3.180917] systemd[1]: Finished Load Kernel Module configfs.
[ 3.184271] systemd[1]: [email protected]: Succeeded.
[ 3.186906] i2c_dev: i2c /dev entries driver
[ 3.188142] systemd[1]: Finished Load Kernel Module fuse.
[ 3.197769] systemd[1]: Mounting FUSE Control File System…
[ 3.203619] systemd[1]: Mounting Kernel Configuration File System…
[ 3.209479] systemd[1]: Started File System Check Daemon to report status.
[ 3.218033] systemd[1]: Finished Load Kernel Modules.
[ 3.224099] systemd[1]: Starting Apply Kernel Variables…
[ 3.225598] systemd[1]: Mounted FUSE Control File System.
[ 3.269044] systemd[1]: Mounted Kernel Configuration File System.
[ 3.292278] systemd[1]: [email protected]: Succeeded.
[ 3.308208] systemd[1]: Finished Load Kernel Module drm.
[ 3.340572] systemd[1]: Finished File System Check on Root Device.
[ 3.342688] systemd[1]: Finished Apply Kernel Variables.
[ 3.347374] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 3.492389] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 3.500605] systemd[1]: Started Journal Service.
[ 3.589018] systemd-journald[140]: Received client request to flush runtime journal.
[ 3.598947] systemd-journald[140]: File /var/log/journal/4c1e4ecba1a049bcae34812380854946/system.journal corrupted or uncleanly shut down, renaming and replacing.
