Hi everyone, I’m trying to get an Arducam IMX510 camera module working with my Raspberry Pi 5. I’ve connected it via the flex cable and double-checked the physical connection — everything seems seated properly. But when I send commands from the Pi to the camera, I get absolutely nothing back. No response at all. Has anyone run into this?
Quick update — I tried swapping to a different flex cable and connector, but still no luck. The camera is completely unresponsive.
Thanks for the details. Can you check the official wiki here: 16MP IMX519 - Arducam Wiki
Also, on the Pi 5, if you’re only connecting one camera, make sure it’s plugged into the front CSI port (the one closer to the edge of the board). The other CSI port is for a second camera and won’t work as the primary. Which port are you currently using?
I’ve now gone through everything on that wiki page twice — correct CSI port, all the steps — and the camera still won’t work. I’m stuck. Is there anything else I can try?
Let’s try a couple more things. First, carefully re-plug both ends of the flex cable — unseat and reseat them completely. Sometimes they look connected but aren’t making good contact.
Then run this on the Pi:
sudo apt install imx500-all
After that finishes, reboot and let us know what happens.
I’ve now done exactly that — re-plugged both ends of the flex cable, ran sudo apt install imx500-all, rebooted — twice. Same result both times, camera is still dead silent. No response whatsoever.
I think I know what’s going on. Based on everything you’ve described, the flex cable at the camera end is very likely reversed — inserted upside down. This is actually a common gotcha with these modules. The Pi-side connection is probably fine, but on the camera module side the cable needs to be flipped 180 degrees.
Here’s what to do:
- Disconnect the flex cable from the camera module only (leave the Pi side alone).
- Rotate the cable 180 degrees (flip it over).
- Re-insert it into the camera module connector.
Give that a try first — hardware first, then we’ll sort out the software side.
Once you’ve got the cable orientation sorted, there’s also the software setup to complete. Follow the IMX519 software guide here:
That covers installing the proper libcamera software and making the necessary changes to config.txt on the Pi. You’ll also want to make sure sudo apt install imx500-all completed successfully and that you’ve rebooted afterwards.
The key thing right now though is that cable flip at the camera end — I’m fairly confident that’s the main issue here.
