Imx477 with raspberry pi 5: ERROR: *** failed to allocate capture buffers for stream ***
Dear Support Team,
I’m getting the following error while using imx477 with Raspberry pi 5 (Bookworm). Please help!
admin@raspberrypi:~ $ libcamera-vid -o test.h264
Could not open any dmaHeap device
[0:51:50.945888279] [2609] INFO Camera camera_manager.cpp:313 libcamera v0.3.0+65-6ddd79b5
[0:51:50.953334490] [2612] INFO RPI pisp.cpp:695 libpisp version v1.0.6 b567f0455680 17-06-2024 (10:20:00)
[0:51:50.970516917] [2612] INFO RPI pisp.cpp:1154 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/imx477@1a to CFE device /dev/media0 and ISP device /dev/media2 using PiSP variant BCM2712_C0
Made X/EGL preview window
Mode selection for 640:480:12:P
SRGGB10_CSI2P,1332x990/0 - Score: 1305.05
SRGGB12_CSI2P,2028x1080/0 - Score: 701.167
SRGGB12_CSI2P,2028x1520/0 - Score: 607.329
SRGGB12_CSI2P,4056x3040/0 - Score: 1494.33
Stream configuration adjusted
[0:51:51.336156226] [2609] INFO Camera camera.cpp:1183 configuring streams: (0) 640x480-YUV420 (1) 2028x1520-BGGR_PISP_COMP1
[0:51:51.336282949] [2612] INFO RPI pisp.cpp:1450 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/imx477@1a - Selected sensor format: 2028x1520-SBGGR12_1X12 - Selected CFE format: 2028x1520-PC1B
dmaHeap allocation failure for rpicam-apps0
admin@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
admin@raspberrypi:~ $ uname -r
6.6.44-v8-16k+
Bug report using Arducam bug report tool is attached.
BUG REPORT
Hi @ios_mx
Already replied to you on this thread :slight_smile: Pi 5(Bookworm OS) compatibility with Arducam camera - #75 by Dion
