HI Dion,
Good to know that the B0274 is 4 lane capable. On my Orin NX 16GB development kit CAM0 is closer to the power. But CAM0 is only 2 lane capable as per NVIDIA.
I am using Jetpack 6.2 tegra_release 36.4.3. I have connected the B0274 to CAM1 which is the only port that is 4 lane capable on the development kit. The default nv_imx477.ko available in this JetPack is getting used.
I am using jetson-io but I don’t see the overlay names like “Camera Arducam Dual” in the display as see in the WiKi (Jetson-io - Arducam Wiki). Might be because it is for a Nano and older JetPack.
I have tried “Camera IMX477 Dual 4 lane / tegra234-p3767-camera-p3768-imx477-dual-4lane.dtbo” but this overlay does a 4 lane setup for CAM0 CSI A-B, and 2 lane setup for CAM1 - CSI C/D. But, on the Orin NX development kit CAM0 only CSI-B is used and therefore only 2 lane. So, with this overlay B0274 is sort of forced to 2 lane mode on CAM0 and and programmed to 2 lane mode on CAM1. So, I don’t think “Camera IMX477 Dual 4 lane” is not the correct overlay for B0274 on CAM1.
So, I wrote an overlay for 4 lane on CSI C-D. Here it is below. Can you please let me know if there is something wrong in the overlay below that jumps at you?
Thanks
// SPDX-License-Identifier: GPL-2.0-only
// SPDX-FileCopyrightText: Copyright (c) 2023-2024, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
/dts-v1/;
/plugin/;
#define CAM0_PWDN TEGRA234_MAIN_GPIO(H, 6)
#define CAM1_PWDN TEGRA234_MAIN_GPIO(AC, 0)
#define CAM_I2C_MUX TEGRA234_AON_GPIO(CC, 3)
#include <dt-bindings/tegra234-p3767-0000-common.h>
overlay-name = “Camera IMX477 Dual 4 lane”;
jetson-header-name = “Jetson 24pin CSI Connector”;
compatible = JETSON_COMPATIBLE_P3768;
fragment@0 {
target-path = "/";
__overlay__ {
tegra-capture-vi {
num-channels = <2>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_vi_in0: endpoint {
port-index = <1>;
bus-width = <4>;
remote-endpoint = <&rbpcv3_imx477_csi_out0>;
port@1 {
reg = <1>;
rbpcv3_imx477_vi_in1: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&rbpcv3_imx477_csi_out1>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <8>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <7500000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vendor.
modules {
module0 {
badge = "jakku_front_RBPCV3";
position = "front";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/cam_i2cmux/i2c@0/rbpcv3_imx477_a@1a";
module1 {
badge = "jakku_rear_RBPCV3";
position = "front";
orientation = "1";
drivernode0 {
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/cam_i2cmux/i2c@1/rbpcv3_imx477_c@1a";
bus@0 {
host1x@13e00000 {
nvcsi@15a00000 {
num-channels = <2>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_csi_in0: endpoint@0 {
port-index = <1>;
bus-width = <4>;
remote-endpoint = <&rbpcv3_imx477_out0>;
port@1 {
reg = <1>;
rbpcv3_imx477_csi_out0: endpoint@1 {
remote-endpoint = <&rbpcv3_imx477_vi_in0>;
channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_csi_in1: endpoint@2 {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&rbpcv3_imx477_out1>;
port@1 {
reg = <1>;
rbpcv3_imx477_csi_out1: endpoint@3 {
remote-endpoint = <&rbpcv3_imx477_vi_in1>;
cam_i2cmux {
status = "okay";
compatible = "i2c-mux-gpio";
#size-cells = <0>;
mux-gpios = <&gpio_aon CAM_I2C_MUX GPIO_ACTIVE_HIGH>;
i2c-parent = <&cam_i2c>;
i2c@0 {
status = "okay";
reg = <0>;
#size-cells = <0>;
rbpcv2_imx219_a@10 {
status = "disabled";
rbpcv3_imx477_a@1a {
reset-gpios = <&gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
compatible = "ridgerun,imx477";
/* I2C device address */
reg = <0x1a>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "imx477";
use_sensor_mode_id = "true";
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* lane_polarity
* Based on the camera connector pin.
* CSIx_D0 | CSIx_D1 | CSI(X+1)_D0 | CSI(X+1)CSIx_D1
* LSB | BIT1 | BIT2 | MSB
* if there is a polarity swap on any lane, the bit corrsponding
* to the lane should be set
* e.g. polarity swap on CSIx_D0 only -> lane_polarity = "1"; 0001
* e.g. polarity swap on CSIx_D1 and CSI(X+1)_D0 -> lane_polarity = "6"; 0110
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 { /* IMX477_MODE_3840x2160 */
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_b";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "3840";
active_h = "2160";
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "10";
readout_orientation = "90";
line_length = "5832";
inherent_gain = "1";
mclk_multiplier = "80";
pix_clk_hz = "600000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "356"; /* 22x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "30000000"; /* 30.0 fps */
step_framerate = "1";
default_framerate = "30000000"; /* 30.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
step_exp_time = "1";
default_exp_time = "2495"; /* us */
embedded_metadata_height = "2";
mode1 { /* IMX477_MODE_1920X1080 */
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
line_length = "3076";
gain_factor = "16";
max_framerate = "60000000"; /* 60.0 fps */
default_framerate = "60000000"; /* 60.0 fps */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_out0: endpoint {
port-index = <1>;
bus-width = <4>;
remote-endpoint = <&rbpcv3_imx477_csi_in0>;
i2c@1 {
status = "okay";
reg = <1>;
#size-cells = <0>;
rbpcv2_imx219_c@10 {
rbpcv3_imx477_c@1a {
reset-gpios = <&gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
reg = <0x1a>;
devnode = "video1";
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
lane_polarity = "0";
active_w = "3840";
active_h = "2160";
gain_factor = "16";
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_out1: endpoint {
status = "okay";
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&rbpcv3_imx477_csi_in1>;
gpio@6000d000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = < CAM1_PWDN 0 CAM0_PWDN 0>;
label = "cam1-pwdn", "cam0-pwdn";
