I try to set up IMX477 cameras. Have spent 2 days with it. Please could someone help?
R32, rev 7.2, board: t186ref.
Using JetPack 4.6.2, fresh install. No luck and I’m stuck.
jetson@ubuntu:~/Arducam$ sudo ls /dev/video*
ls: cannot access ‘/dev/video*’: No such file or directory
jetson@ubuntu:~/Arducam$ i2cdetect -l
i2c-3 i2c 3190000.i2c I2C adapter
i2c-1 i2c c240000.i2c I2C adapter
i2c-101 i2c 15210000.nvdisplay I2C adapter
i2c-8 i2c 31e0000.i2c I2C adapter
i2c-6 i2c 31c0000.i2c I2C adapter
i2c-4 i2c Tegra BPMP I2C adapter I2C adapter
i2c-2 i2c 3180000.i2c I2C adapter
i2c-0 i2c 3160000.i2c I2C adapter
i2c-9 i2c i2c-2-mux (chan_id 0) I2C adapter
i2c-10 i2c i2c-2-mux (chan_id 1) I2C adapter
i2c-7 i2c c250000.i2c I2C adapter
i2c-5 i2c 31b0000.i2c I2C adapter
jetson@ubuntu:~/Arducam$ lsusb
Bus 002 Device 002: ID 0424:5744 Standard Microsystems Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8087:0a2b Intel Corp.
Bus 001 Device 006: ID 0424:2740 Standard Microsystems Corp.
Bus 001 Device 005: ID 0461:0010 Primax Electronics, Ltd HP PR1101U / Primax PMX-KPR1101U Keyboard
Bus 001 Device 004: ID 046d:c05a Logitech, Inc. M90/M100 Optical Mouse
Bus 001 Device 002: ID 0424:2744 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
jetson@ubuntu:~/Arducam$ cat /proc/version
Linux version 4.9.253-tegra (jenkins@feaf98b9a84d) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed May 25 06:32:34 UTC 2022
jetson@ubuntu:~/Arducam$ sudo dpkg -i arducam-nvidia-l4t-kernel-t194-4.9.253-tegra-32.7.2-20220525063328_arm64_imx477.deb
[sudo] password for jetson:
Selecting previously unselected package arducam-nvidia-l4t-kernel.
(Reading database … 176119 files and directories currently installed.)
Preparing to unpack arducam-nvidia-l4t-kernel-t194-4.9.253-tegra-32.7.2-20220525063328_arm64_imx477.deb …
Unpacking arducam-nvidia-l4t-kernel (4.9.253-tegra-32.7.2-20220525063328) …
Setting up arducam-nvidia-l4t-kernel (4.9.253-tegra-32.7.2-20220525063328) …
dpkg: error processing package arducam-nvidia-l4t-kernel (–install):
I’d be more than thankful if someone gives a working idea.
