Raspberry Pi HQ camera (12 Mpx) -
NVIDIA Jetson Nano B01 (4GB), using Jetpack 4.6.1 -
Instruction for removing the resistor (RidgerRun)
Instructions for using NVIDIA default driver
Looking to the imx477-error-on-jetson-nano-r32-6-1 topic -
I am working with a Jetson Nano 4GB and a raspberry Pi HQ camera (I discovered yours right after my purchase my bad). It works fine excepted on software parameters.
According to your docs, I set up the IMX477 camera driver and device tree configuration using jetson-io.py
First, there is weird things when I configure IMX477 CSI connector : configuration of pins are on N/A but it seems to be ok because I can use the camera (I guess a bad display in jetson-io).
So I can use the camera using gstreamer with nvarguscamera plugin, however, when it lists all the mode available, only 2Mpx and 8Mpx are available :
Is that caused to NVIDIA driver which use the driver for the raspberry pi v2 camera (8Mpx) ?
Another point is that I can set up different resolutions on gstreamer, like 4032x3040 or 6000x4000 and the image captured are at this resolution (4032x3040 or 6000x4000). I don’t understand why, what is gstreamer doing to perform a 6000x4000 acquisition ? Is there any software treatment after the acquisition to increase the resolution ?
Here is my dmesg log for imx477 :
$ dmesg | grep imx477
[ 1.304736] imx477 7-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.606520] imx477 8-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.906886] imx477 8-001a: imx477_board_setup: error during i2c read probe (-121)
[ 1.914482] imx477 8-001a: board setup failed
[ 1.918946] imx477: probe of 8-001a failed with error -121
[ 2.174493] vi 54080000.vi: subdev imx477 7-001a bound
May I could use your driver even if it is a raspberry pi HQ camera (using https ://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/install_full.sh) ? What do you suggest ?
Thank you
