I have the same problem too.
I downloaded the driver - arducam-nvidia-l4t-kernel_4.9.140-32.4.4-20201026143033_arm64_imx477.deb from https://github.com/ArduCAM/MIPI_Camera/releases/tag/v0.0.1
I get this error -
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available
I bought an IMX477 camera (SKU: B0251) with Jetson Nano 4Gi
I never used any other camera on this system before
Here’s my dmesg output
[ 1.560299] imx477 7-001a: imx477_board_setup: error during i2c read probe (-121)
[ 1.568024] imx477 7-001a: board setup failed
[ 1.572498] imx477: probe of 7-001a failed with error -121
[ 1.572883] imx477 8-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.880826] imx477 8-001a: board setup failed
[ 1.885416] imx477: probe of 8-001a failed with error -121
The complete log is as follows
[ 0.000000] Linux version 4.9.140-tegra ([email protected]) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #2 SMP PREEMPT Mon Oct 26 09:40:50 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node [email protected], reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: [email protected]
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefa8000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 [email protected] section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 [email protected] video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 [email protected] core_edp_mv=1125 core_edp_ma=4000 [email protected] is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29228(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562216K/4159488K available (15294K kernel code, 2938K rwdata, 6592K rodata, 8576K init, 609K bss, 122136K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff80095f0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095f0000 - 0xffffff8009e50000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e50000 - 0xffffff800a12e808 ( 2939 KB)
[ 0.000000] .bss : 0xffffff800a12e808 - 0xffffff800a1c6f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /[email protected]: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001720] Console: colour dummy device 80x25
[ 0.001728] console [tty0] enabled
[ 0.001734] bootconsole [uart8250] disabled
[ 0.001752] kmemleak: Kernel memory leak detector disabled
[ 0.001773] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001785] pid_max: default: 32768 minimum: 301
[ 0.002239] Security Framework initialized
[ 0.002466] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002476] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003640] ftrace: allocating 47144 entries in 185 pages
[ 0.174106] sched-energy: CPU device node has no sched-energy-costs
[ 0.174138] ASID allocator initialised with 65536 entries
[ 0.211960] tegra-id: chipid=22117.
[ 0.211974] tegra-id: opt_subrevision=0.
[ 0.211992] Tegra Speedo/IDDQ fuse revision 4
[ 0.211997] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.212002] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.212008] Tegra: CPU Speedo Value 1974, SoC Speedo Value 1884, GPU Speedo Value 1995
[ 0.212012] Tegra: CPU IDDQ Value 1444, SoC IDDQ Value 1692, GPU IDDQ Value 2025
[ 0.212032] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.212048] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.212055] DTB Build time: Oct 26 2020 11:36:37
[ 0.261095] CPU1: Booted secondary processor [411fd071]
[ 0.292989] CPU2: Booted secondary processor [411fd071]
[ 0.324944] CPU3: Booted secondary processor [411fd071]
[ 0.325029] Brought up 4 CPUs
[ 0.325036] SMP: Total of 4 processors activated.
[ 0.325045] CPU features: detected feature: 32-bit EL0 Support
[ 0.325315] CPU: All CPU(s) started at EL2
[ 0.325335] alternatives: patching kernel code
[ 0.333710] devtmpfs: initialized
[ 0.372343] Initilizing CustomIPI irq domain
[ 0.372740] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.372770] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.384250] pinctrl core: initialized pinctrl subsystem
[ 0.384860] OS set in device tree is not L4T.
[ 0.385361] regulator-dummy: no parameters
[ 0.385637] Initializing plugin-manager
[ 0.385794] Plugin module not found
[ 0.385984] node /plugin-manager/[email protected] match with board >=3448-0000-100
[ 0.386525] node /plugin-manager/[email protected] match with board >=3448-0000-101
[ 0.387382] node /plugin-manager/[email protected] match with odm-data enable-tegra-wdt
[ 0.387762] node /plugin-manager/[email protected] match with odm-data enable-tegra-wdt
[ 0.388332] node /plugin-manager/[email protected] match with board >=3448-0000-300
[ 0.390344] node /plugin-manager/[email protected] match with board >=3448-0000-300
[ 0.394050] NET: Registered protocol family 16
[ 0.395547] pstore: using zlib compression
[ 0.395592] console [pstore-1] enabled
[ 0.395597] pstore: Registered ramoops as persistent store backend
[ 0.395602] ramoops: attached [email protected], ecc: 0/0
[ 0.405119] cpuidle: using governor menu
[ 0.408567] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.410539] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e54000)
[ 0.410562] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413653] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.416104] Serial: AMBA PL011 UART driver
[ 0.416624] tegra_powergate_init: DONE
[ 0.416641] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.416647] DTB Build time: Oct 26 2020 11:36:37
[ 0.418698] Tegra reboot handler registered.
[ 0.423335] iommu: Adding device tegra-carveouts to group 0
[ 0.423486] platform tegra-carveouts: domain=ffffffc0f9be53d8 allocates as[0]=ffffffc0f94540a8
[ 0.423840] iommu: Adding device smmu_test to group 1
[ 0.423887] platform smmu_test: domain=ffffffc0f9be5618 allocates as[0]=ffffffc0f9454110
[ 0.424707] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.424759] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.424811] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.424822] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.424846] mc-err: mcerr ops are set to t21x
[ 0.434923] iommu: Adding device 70090000.xusb to group 2
[ 0.435203] iommu: Adding device 70006000.serial to group 3
[ 0.435279] platform 70006000.serial: domain=ffffffc0f94b2618 allocates as[0]=ffffffc0f9454178
[ 0.435707] iommu: Adding device 70006040.serial to group 4
[ 0.435968] iommu: Adding device 70006200.serial to group 5
[ 0.436191] iommu: Adding device sound to group 6
[ 0.436243] platform sound: domain=ffffffc0f94b2b58 allocates as[0]=ffffffc0f94541e0
[ 0.436804] iommu: Adding device 7000d400.spi to group 7
[ 0.437208] iommu: Adding device 7000d600.spi to group 8
[ 0.437493] iommu: Adding device 70410000.spi to group 9
[ 0.437799] iommu: Adding device 50000000.host1x to group 10
[ 0.438068] iommu: Adding device 54080000.vi to group 11
[ 0.438457] iommu: Adding device 54600000.isp to group 12
[ 0.438709] iommu: Adding device 54680000.isp to group 13
[ 0.439013] iommu: Adding device tegradc.0 to group 14
[ 0.439068] platform tegradc.0: domain=ffffffc0f94bfa98 allocates as[0]=ffffffc0f9454248
[ 0.443261] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[ 0.443659] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.443997] iommu: Adding device tegradc.1 to group 15
[ 0.444045] platform tegradc.1: domain=ffffffc0f94bfcd8 allocates as[0]=ffffffc0f94542b0
[ 0.448209] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[ 0.448596] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.448847] iommu: Adding device 54340000.vic to group 16
[ 0.449073] iommu: Adding device 544c0000.nvenc to group 17
[ 0.449290] iommu: Adding device 54500000.tsec to group 18
[ 0.449493] iommu: Adding device 54100000.tsecb to group 19
[ 0.449688] iommu: Adding device 54480000.nvdec to group 20
[ 0.449901] iommu: Adding device 54380000.nvjpg to group 21
[ 0.450926] iommu: Adding device 546c0000.i2c to group 22
[ 0.451253] iommu: Adding device 57000000.gpu to group 23
[ 0.451308] platform 57000000.gpu: domain=ffffffc0f94cecd8 allocates as[0]=ffffffc0f9454318
[ 0.451345] platform 57000000.gpu: domain=ffffffc0f94cecd8 allocates as[1]=ffffffc0f9454380
[ 0.451385] platform 57000000.gpu: domain=ffffffc0f94cecd8 allocates as[2]=ffffffc0f94543e8
[ 0.451423] platform 57000000.gpu: domain=ffffffc0f94cecd8 allocates as[3]=ffffffc0f9454450
[ 0.452320] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.452332] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.452345] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.452349] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.452353] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.505170] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.505177] tegra-pmc: Clear bootloader IO dpd settings
[ 0.505196] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.505256] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.505550] iommu: Adding device 70012000.se to group 24
[ 0.506300] iommu: Adding device 7000c000.i2c to group 25
[ 0.506552] iommu: Adding device 7000c400.i2c to group 26
[ 0.506811] iommu: Adding device 7000c500.i2c to group 27
[ 0.507060] iommu: Adding device 7000c700.i2c to group 28
[ 0.507338] iommu: Adding device 7000d000.i2c to group 29
[ 0.507607] iommu: Adding device 7000d100.i2c to group 30
[ 0.507893] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.507946] platform sdhci-tegra.0: domain=ffffffc0f9561e58 allocates as[0]=ffffffc0f94544b8
[ 0.508748] iommu: Adding device 700d0000.xudc to group 32
[ 0.512095] vdd-ac-bat: 5000 mV
[ 0.512454] vdd-5v0-sys: 5000 mV
[ 0.513436] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.513508] vdd-5v0-hdmi: 5000 mV
[ 0.513928] vdd-1v8-sys: 1800 mV
[ 0.514328] vdd-fan: supplied by vdd-5v0-sys
[ 0.514365] vdd-fan: 5000 mV
[ 0.514764] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.514825] vdd-usb-vbus: 5000 mV
[ 0.515357] vdd-usb-vbus2: 5000 mV
[ 0.546119] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.549406] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.550517] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.550539] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.550574] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.550964] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.558915] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.559277] SCSI subsystem initialized
[ 0.559532] libata version 3.00 loaded.
[ 0.559833] usbcore: registered new interface driver usbfs
[ 0.559882] usbcore: registered new interface driver hub
[ 0.559951] usbcore: registered new device driver usb
[ 0.563979] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.569323] vdd-core: 600 <–> 1162 mV at 1125 mV
[ 0.570182] random: fast init done
[ 0.570299] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.573112] vdd-ddr-1v1: 1150 mV
[ 0.577125] vdd-pre-reg-1v35: 1350 mV
[ 0.581112] vdd-1v8: 1800 mV
[ 0.585107] avdd-sys-1v2: 1200 mV
[ 0.589107] vdd-pex-1v0: 1050 mV
[ 0.589737] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.590277] max77620-ldo3: at 3100 mV
[ 0.593111] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.593711] max77620-ldo5: at 3100 mV
[ 0.597110] vddio-sdmmc3-ap: 1800 <–> 3300 mV at 2800 mV
[ 0.601108] avdd-1v05-pll: 1050 mV
[ 0.605107] avdd-io-hdmi-dp: 1050 mV
[ 0.607593] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.607929] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.608213] max77620 4-003c: max77620 probe successful
[ 0.610999] media: Linux media interface: v0.10
[ 0.611053] Linux video capture interface: v2.00
[ 0.611948] pps_core: LinuxPPS API ver. 1 registered
[ 0.611954] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.611978] PTP clock support registered
[ 0.615241] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.616195] Advanced Linux Sound Architecture Driver Initialized.
[ 0.616838] Bluetooth: Core ver 2.22
[ 0.616885] NET: Registered protocol family 31
[ 0.616890] Bluetooth: HCI device and connection manager initialized
[ 0.616905] Bluetooth: HCI socket layer initialized
[ 0.616913] Bluetooth: L2CAP socket layer initialized
[ 0.616940] Bluetooth: SCO socket layer initialized
[ 0.618675] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.618693] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.618741] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.618756] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.622432] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.623800] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.623867] vdd-3v3-sys: 3300 mV
[ 0.624144] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.629203] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629699] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.629769] vdd-3v3-sd: 3300 mV
[ 0.630679] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.630719] avdd-io-edp-1v05: 1050 mV
[ 0.631139] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.631179] vdd-usb-hub-en: 5000 mV
[ 0.632635] camchar: rtcpu character device driver loaded
[ 0.633363] extcon-gpio-states extcon:[email protected]: Cable state:0, cable id:0
[ 0.634784] clocksource: Switched to clocksource arch_sys_counter
[ 0.676261] VFS: Disk quotas dquot_6.6.0
[ 0.676396] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.676904] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.677335] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.677351] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.677554] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.677561] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.677573] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.677599] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.677605] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.677618] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.677627] nvmap_page_pool_init: Total RAM pages: 1009338
[ 0.677633] nvmap_page_pool_init: nvmap page pool size: 126167 pages (492 MB)
[ 0.677721] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.678244] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.679335] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.687945] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.688416] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.688792] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.689063] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.689246] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.689538] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.689542] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.689976] NET: Registered protocol family 2
[ 0.691092] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.691313] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.691818] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.691977] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.692058] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.692468] NET: Registered protocol family 1
[ 0.693184] RPC: Registered named UNIX socket transport module.
[ 0.693190] RPC: Registered udp transport module.
[ 0.693193] RPC: Registered tcp transport module.
[ 0.693197] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.693212] PCI: CLS 0 bytes, default 64
[ 0.693476] Trying to unpack rootfs image as initramfs…
[ 0.924624] Freeing initrd memory: 5356K
[ 0.934895] host1x 50000000.host1x: initialized
[ 0.936848] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.940165] audit: initializing netlink subsys (disabled)
[ 0.940262] audit: type=2000 audit(0.787:1): initialized
[ 0.941029] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.951112] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.952599] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.953391] 9p: Installing v9fs 9p2000 file system support
[ 0.956734] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.956887] io scheduler noop registered
[ 0.957181] io scheduler cfq registered (default)
[ 0.959914] gic 702f9000.agic: GIC IRQ controller registered
[ 0.963262] iommu: Adding device 702ef000.adsp to group 33
[ 0.972175] iommu: Adding device [email protected]:adsp_audio to group 34
[ 0.972333] tegra-aconnect [email protected]: Tegra ACONNECT bus registered
[ 0.972947] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8a29c14
[ 0.972955] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.974606] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.974711] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.974847] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.975041] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.975129] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.975217] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.975299] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.975386] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.975471] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.975557] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.981538] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.983376] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.985312] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.986593] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.986989] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.988185] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.988414] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.988699] Adding domain tsec-pd to PM domain host1x-pd
[ 0.991136] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.992098] tsec 54500000.tsec: initialized
[ 0.993661] tsec 54100000.tsecb: initialized
[ 0.994390] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.997918] nvdec 54480000.nvdec: initialized
[ 0.999012] Adding domain vic03-pd to PM domain host1x-pd
[ 0.999189] Adding domain msenc-pd to PM domain host1x-pd
[ 0.999350] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.003378] falcon 54340000.vic: initialized
[ 1.004602] falcon 544c0000.nvenc: initialized
[ 1.005936] falcon 54380000.nvjpg: initialized
[ 1.010292] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.010336] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.010365] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.010545] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.010643] display board info: id 0x0, fab 0x0
[ 1.010655] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.010661] tegra_cec 70015000.tegra_cec: probed
[ 1.010710] generic_infoframe_type: 0x87
[ 1.010910] tegradc tegradc.0: DT parsed successfully
[ 1.010961] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.011527] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.018946] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.019462] tegradc tegradc.0: probed
[ 1.025515] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.027010] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.027023] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.027446] kfuse 7000fc00.kfuse: initialized
[ 1.029030] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.031102] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.031120] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.031126] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.031132] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.031139] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.031259] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.031439] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.031525] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.031846] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.031958] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.032240] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.032255] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.032457] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[ 1.032515] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 1.032785] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 1.033524] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.033544] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.034112] pwm-regulator pwm_regulators:[email protected]: PWM regulator registration passed
[ 1.035909] vdd-gpu: applied init 1000000uV constraint
[ 1.035920] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.036371] pwm-regulator pwm_regulators:[email protected]: PWM regulator registration passed
[ 1.041372] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.041532] No Device Node present for smmu client: serial8250 !!
[ 1.041545] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.041606] iommu: Adding device serial8250 to group 35
[ 1.043030] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.043359] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 1.043406] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.043451] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 1.043478] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 1.043709] pci 0000:02:00.0: supports D1 D2
[ 1.043715] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.046436] console [ttyS0] disabled
[ 1.046495] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.046581] console [ttyS0] enabled
[ 1.047517] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.047805] serial-tegra 70006200.serial: RX in PIO mode
[ 1.047897] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.048837] [drm] Initialized
[ 1.052003] Console: switching to colour frame buffer device 240x67
[ 1.052133] tegradc tegradc.0: fb registered
[ 1.054971] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 1.055070] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.055079] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 1.055085] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.055098] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[ 1.055127] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.055137] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.055150] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 1.055171] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 1.055190] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.055199] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 1.055204] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.055212] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 1.055868] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.055876] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.055884] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.056032] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 1.056294] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.056301] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.056308] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.056429] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 1.059090] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.059149] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.059670] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.059681] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.061157] brd: module loaded
[ 1.066754] loop: module loaded
[ 1.066909] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.067046] tegra_profiler: auth: init
[ 1.068495] THERMAL EST: found 2 subdevs
[ 1.068505] THERMAL EST num_resources: 0
[ 1.068516] [THERMAL EST subdev 0]
[ 1.068523] [THERMAL EST subdev 1]
[ 1.069153] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.069159] THERMAL EST: thz register success.
[ 1.069324] THERMAL EST: end of probe, return err: 0
[ 1.070586] sd: No Scsi addr parsed to reserve index
[ 1.070627] hisi_sas: driver version v1.6
[ 1.075860] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.077087] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.077099] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.080296] libphy: Fixed MDIO Bus: probed
[ 1.081046] tun: Universal TUN/TAP device driver, 1.6
[ 1.081051] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 1.082115] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.082122] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.082184] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.082187] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.082242] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.082246] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.082298] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.082304] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.083478] r8168 0000:02:00.0: enabling device (0000 → 0003)
[ 1.083511] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.086014] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.086019] Extcon AUX1(HDMI) enable
[ 1.087053] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.087131] tegradc tegradc.1: No lt-data, using default setting
[ 1.087158] tegradc tegradc.1: No hpd-gpio in DT
[ 1.087190] tegradc tegradc.1: DT parsed successfully
[ 1.087249] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.088724] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.100940] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.101075] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:ec:1a:84 from device tree
[ 1.101732] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.101799] r8168 Copyright (C) 2017 Realtek NIC software team <[email protected]>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.102617] PPP generic driver version 2.4.2
[ 1.103162] PPP BSD Compression module registered
[ 1.103168] PPP Deflate Compression module registered
[ 1.103216] PPP MPPE Compression module registered
[ 1.103224] NET: Registered protocol family 24
[ 1.103302] usbcore: registered new interface driver r8152
[ 1.103341] usbcore: registered new interface driver asix
[ 1.103419] usbcore: registered new interface driver ax88179_178a
[ 1.103458] usbcore: registered new interface driver cdc_ether
[ 1.103491] usbcore: registered new interface driver net1080
[ 1.103521] usbcore: registered new interface driver cdc_subset
[ 1.103554] usbcore: registered new interface driver zaurus
[ 1.103605] usbcore: registered new interface driver cdc_ncm
[ 1.103822] VFIO - User Level meta-driver version: 0.3
[ 1.103893] tegradc tegradc.1: probed
[ 1.104252] tegradc tegradc.1: fb registered
[ 1.107456] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.107465] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.107474] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.107488] tegradc tegradc.1: blank - powerdown
[ 1.107510] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.107514] Extcon DP: HPD disabled
[ 1.107519] hpd: hpd_switch 0
[ 1.107523] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.107531] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.107538] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.109737] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.109762] ehci-pci: EHCI PCI platform driver
[ 1.109815] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.109825] ohci-pci: OHCI PCI platform driver
[ 1.109867] ohci-platform: OHCI generic platform driver
[ 1.112532] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.113585] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.114833] tegra-xusb 70090000.xusb: extcon 0: ffffffc0fa5d1000 id
[ 1.116150] usbcore: registered new interface driver uas
[ 1.116212] usbcore: registered new interface driver usb-storage
[ 1.116364] usbcore: registered new interface driver usbserial
[ 1.120840] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.122366] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.122397] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.122414] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.122455] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.123120] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.123155] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.123311] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.123317] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.123322] usb usb1: Product: xHCI Host Controller
[ 1.123326] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.123330] usb usb1: SerialNumber: 70090000.xusb
[ 1.123505] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.123515] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.123541] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.123777] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.124002] hub 1-0:1.0: USB hub found
[ 1.124039] hub 1-0:1.0: 5 ports detected
[ 1.124544] mousedev: PS/2 mouse device common for all mice
[ 1.124547] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.124556] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.124604] usbcore: registered new interface driver xpad
[ 1.124636] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.124747] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.124753] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.124758] usb usb2: Product: xHCI Host Controller
[ 1.124762] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.124766] usb usb2: SerialNumber: 70090000.xusb
[ 1.125243] hub 2-0:1.0: USB hub found
[ 1.125275] hub 2-0:1.0: 4 ports detected
[ 1.218233] tegradc tegradc.0: blank - powerdown
[ 1.226844] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.226898] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.254786] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.256900] rtc rtc1: alarm rtc device
[ 1.256912] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.256928] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.257303] i2c /dev entries driver
[ 1.258455] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.258457] Extcon AUX1(HDMI) disable
[ 1.259051] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.259429] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.259434] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.259938] imx477 7-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.290069] tegradc tegradc.0: unblank
[ 1.330414] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.330496] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.331556] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.331572] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.366318] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.366322] Extcon AUX1(HDMI) enable
[ 1.381771] tegradc tegradc.0: sync windows ret = 246
[ 1.409218] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.409222] Extcon HDMI: HPD enabled
[ 1.409245] tegradc tegradc.0: hdmi: plugged
[ 1.450788] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.479775] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.479781] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.479785] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.479790] usb 1-2: Manufacturer: Generic
[ 1.480727] hub 1-2:1.0: USB hub found
[ 1.481304] hub 1-2:1.0: 4 ports detected
[ 1.560225] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x1a
[ 1.602794] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 1.624431] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 1.624438] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.770791] usb 1-2.1: new low-speed USB device number 4 using tegra-xusb
[ 1.796905] usb 1-2.1: New USB device found, idVendor=1c4f, idProduct=0002
[ 1.796911] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.796916] usb 1-2.1: Product: USB Keyboard
[ 1.796920] usb 1-2.1: Manufacturer: SIGMACHIP
[ 1.873153] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x1a
[ 1.873223] imx477 8-001a: imx477_board_setup: error during i2c read probe (-121)
[ 1.874793] usb 1-2.3: new low-speed USB device number 5 using tegra-xusb
[ 1.886668] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.888755] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.888761] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.889058] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.889071] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.889078] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.889211] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.889221] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.889228] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.889373] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.889382] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.889387] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.889573] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.890106] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.890153] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.890174] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.890191] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.890200] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.891143] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.891158] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.891314] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.891337] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.891691] parse_throttle_dt_data: Num cap clks = 6
[ 1.891696] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.891703] parse_throttle_dt_data: clk=gpu type=4
[ 1.891724] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.891742] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.891762] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.891766] parse_throttle_dt_data: clk=emc type=3
[ 1.892098] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.892194] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.892295] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.892863] FAN dev name: pwm-fan
[ 1.892906] FAN:gpio request success.
[ 1.892958] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.893182] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.893293] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.893300] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.893373] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.893379] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.893384] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.893389] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.893394] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.893399] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.893404] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.893408] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.893413] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.893419] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.894027] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.894289] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.895019] device-mapper: uevent: version 1.0.3
[ 1.895415] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
[ 1.898067] tegra210-cpufreq cpufreq: probe()…completed
[ 1.899193] sdhci: Secure Digital Host Controller Interface driver
[ 1.899195] sdhci: Copyright(c) Pierre Ossman
[ 1.899197] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.899683] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.900063] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.900185] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.903076] usb 1-2.3: New USB device found, idVendor=04f2, idProduct=0939
[ 1.903081] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.903084] usb 1-2.3: Product: USB Optical Mouse
[ 1.903087] usb 1-2.3: Manufacturer: PixArt
[ 1.905286] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.905803] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.909632] input: SIGMACHIP USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:1C4F:0002.0001/input/input0
[ 1.947076] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.967290] hid-generic 0003:1C4F:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-70090000.xusb-2.1/input0
[ 1.969863] input: SIGMACHIP USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.1/0003:1C4F:0002.0002/input/input1
[ 2.027025] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-70090000.xusb-2.1/input1
[ 2.028853] input: PixArt USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:04F2:0939.0003/input/input2
[ 2.029248] hid-generic 0003:04F2:0939.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-70090000.xusb-2.3/input0
[ 2.029295] usbcore: registered new interface driver usbhid
[ 2.029297] usbhid: USB HID core driver
[ 2.034963] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 2.035321] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 2.037165] nvpmodel: initialized successfully
[ 2.038154] usbcore: registered new interface driver snd-usb-audio
[ 2.038211] No Device Node present for smmu client: snd-soc-dummy !!
[ 2.038216] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 2.038236] iommu: Adding device snd-soc-dummy to group 36
[ 2.038807] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.065968] OPE platform probe
[ 2.066061] OPE platform probe successful
[ 2.066380] OPE platform probe
[ 2.066460] OPE platform probe successful
[ 2.089106] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.089233] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.089356] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.089475] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.089591] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.089706] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.089826] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.089943] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.090060] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.090189] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.101787] u32 classifier
[ 2.101790] Actions configured
[ 2.101865] Initializing XFRM netlink socket
[ 2.102576] NET: Registered protocol family 10
[ 2.103330] NET: Registered protocol family 17
[ 2.103342] NET: Registered protocol family 15
[ 2.103414] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.103460] Bluetooth: RFCOMM socket layer initialized
[ 2.103469] Bluetooth: RFCOMM ver 1.11
[ 2.103475] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.103480] Bluetooth: HIDP socket layer initialized
[ 2.103498] 9pnet: Installing 9P2000 support
[ 2.103533] Key type dns_resolver registered
[ 2.104074] Registered cp15_barrier emulation handler
[ 2.104083] Registered setend emulation handler
[ 2.104090] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -113.
[ 2.104094] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.105153] registered taskstats version 1
[ 2.105784] Adding domain ve2-pd to PM domain host1x-pd
[ 2.106022] Adding domain ve-pd to PM domain host1x-pd
[ 2.108072] isp 54600000.isp: initialized
[ 2.109002] isp 54680000.isp: initialized
[ 2.119273] last reset is due to software reset
[ 2.119278] KERNEL: PMC reset status reg: 0x3
[ 2.119339] BL: PMC reset status reg: 0x3
[ 2.119342] BL: PMIC poweroff Event Recorder: 0x0
[ 2.120843] clk_cbus_recalc_rate: no gbus parent
[ 2.120849] clk_cbus_round_rate: no gbus parent
[ 2.120851] clk_cbus_round_rate: no gbus parent
[ 2.120857] clk_cbus_recalc_rate: no gbus parent
[ 2.120958] clk_cbus_recalc_rate: no gbus parent
[ 2.120962] clk_cbus_round_rate: no gbus parent
[ 2.120964] clk_cbus_round_rate: no gbus parent
[ 2.120968] clk_cbus_recalc_rate: no gbus parent
[ 2.121657] tegra_dvfs: GPU-cap: registered
[ 2.121715] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 2.121718] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 2.121720] tegra dvfs: vdd-gpu: nominal 1088mV, offset 708000uV, step 10000uV, scaling enabled
[ 2.132054] tegra_dvfs: vdd-gpu-vts: registered
[ 2.135347] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 2.135983] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 2.136521] input: gpio-keys as /devices/gpio-keys/input/input4
[ 2.153438] mmc0: hw tuning done …
[ 2.153482] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[ 2.154407] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input3
[ 2.157967] mmcblk0: mmc0:59b4 6aLHQ 59.6 GiB
[ 2.163701] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.167464] tegra_rtc 7000e000.rtc: setting system clock to 2020-10-30 05:30:09 UTC (1604035809)
[ 2.168539] vi 54080000.vi: vi_probe: ++
[ 2.171844] vi 54080000.vi: initialized
[ 2.173869] vi 54080000.vi: subdev nvcsi–2 bound
[ 2.173970] vi 54080000.vi: subdev nvcsi–1 bound
[ 2.174195] mmcblk mmc0:59b4: Card claimed for testing.
[ 2.174819] Disable partitions left on by BL
[ 2.174823] disb
[ 2.174864] bwmgr: missing cdev-type property
[ 2.174993] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.175000] DRAM derating cdev registered.
[ 2.176078] vdd-fan: disabling
[ 2.176082] vdd-usb-vbus: disabling
[ 2.176084] vdd-usb-vbus2: disabling
[ 2.176094] vddio-sdmmc3-ap: disabling
[ 2.176178] avdd-io-edp-1v05: disabling
[ 2.176181] vdd-usb-hub-en: disabling
[ 2.176262] ALSA device list:
[ 2.176267] #0: tegra-hda at 0x70038000 irq 83
[ 2.176270] #1: tegra-snd-t210ref-mobile-rt565x
[ 2.179374] Freeing unused kernel memory: 8576K
[ 2.203670] Root device found: mmcblk0p1
[ 2.204728] Found dev node: /dev/mmcblk0p1
[ 2.248744] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.249517] Rootfs mounted over mmcblk0p1
[ 2.273828] Switching from initrd to actual rootfs
[ 2.516846] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.529223] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.556657] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.557463] systemd[1]: Detected architecture arm64.
[ 2.580547] systemd[1]: Set hostname to <sashidhar-desktop>.
[ 2.718737] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.718747] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.886632] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.888402] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.888510] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.888530] systemd[1]: Reached target Swap.
[ 2.888578] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.890408] systemd[1]: Created slice User and Session Slice.
[ 2.890568] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.890612] systemd[1]: Reached target User and Group Name Lookups.
[ 2.930133] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.088489] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.092238] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.092259] cpu-throttle-alert cooling device registered.
[ 3.092390] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.092405] gpu-throttle-alert cooling device registered.
[ 3.092549] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.092562] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.092575] hot-surface-alert cooling device registered.
[ 3.227522] systemd-journald[2020]: Received request to flush runtime journal from PID 1
[ 4.216229] random: crng init done
[ 4.219664] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.682763] using random self ethernet address
[ 4.687577] using random host ethernet address
[ 5.218054] Intel(R) Wireless WiFi driver for Linux
[ 5.218058] Copyright(c) 2003- 2015 Intel Corporation
[ 5.218281] iwlwifi 0000:01:00.0: enabling device (0000 → 0002)
[ 5.294014] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 5.294889] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.294893] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.304870] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.468204] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 5.477505] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.490508] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 5.499849] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.511568] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 5.522084] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.600452] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 5.619244] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.647746] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.647754] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.647758] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.647761] usb 2-1: Manufacturer: Generic
[ 5.651281] hub 2-1:1.0: USB hub found
[ 5.652089] hub 2-1:1.0: 4 ports detected
[ 5.677867] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 5.680778] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 5.681525] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 5.802834] usb 2-1: usb_suspend_both: status 0
[ 5.803008] usb usb2: usb_suspend_both: status 0
[ 5.803409] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 5.804302] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 5.812413] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 5.851976] Mass Storage Function, version: 2009/09/11
[ 5.851981] LUN: removable file: (no medium)
[ 5.859999] using random self ethernet address
[ 5.860002] using random host ethernet address
[ 5.933963] rndis0: HOST MAC ce:13:54:a1:6a:44
[ 5.934220] rndis0: MAC ce:13:54:a1:6a:45
[ 5.953488] usb0: HOST MAC ce:13:54:a1:6a:46
[ 5.953519] usb0: MAC ce:13:54:a1:6a:47
[ 5.953543] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 5.954482] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 5.954501] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.954572] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 5.954876] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 5.955176] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 5.957684] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 5.957709] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 5.957971] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 5.964053] l4tbr0: port 1(rndis0) entered blocking state
[ 5.964056] l4tbr0: port 1(rndis0) entered disabled state
[ 5.967297] device rndis0 entered promiscuous mode
[ 5.974165] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.989896] l4tbr0: port 2(usb0) entered blocking state
[ 5.989901] l4tbr0: port 2(usb0) entered disabled state
[ 5.990070] device usb0 entered promiscuous mode
[ 6.001546] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.173540] usbcore: registered new interface driver btusb
[ 6.174832] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 6.175787] Bluetooth: hci0: Device revision is 16
[ 6.175791] Bluetooth: hci0: Secure boot is enabled
[ 6.175793] Bluetooth: hci0: OTP lock is enabled
[ 6.175796] Bluetooth: hci0: API lock is enabled
[ 6.175798] Bluetooth: hci0: Debug lock is disabled
[ 6.175801] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 6.245247] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 6.639536] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.639549] Bluetooth: BNEP socket layer initialized
[ 6.660823] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.661966] eth0: 0xffffff800a3ee000, 00:04:4b:ec:1a:84, IRQ 406
[ 6.721961] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.789877] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.793264] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.794000] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.919702] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.920067] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.989168] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.097267] zram: Added device: zram0
[ 7.099023] zram: Added device: zram1
[ 7.099470] zram: Added device: zram2
[ 7.099978] zram: Added device: zram3
[ 7.120893] zram0: detected capacity change from 0 to 518565888
[ 7.164486] Adding 506408k swap on /dev/zram0. Priority:5 extents:1 across:506408k SS
[ 7.167948] zram1: detected capacity change from 0 to 518565888
[ 7.230386] Adding 506408k swap on /dev/zram1. Priority:5 extents:1 across:506408k SS
[ 7.241335] zram2: detected capacity change from 0 to 518565888
[ 7.253146] Adding 506408k swap on /dev/zram2. Priority:5 extents:1 across:506408k SS
[ 7.258945] zram3: detected capacity change from 0 to 518565888
[ 7.270124] Adding 506408k swap on /dev/zram3. Priority:5 extents:1 across:506408k SS
[ 7.272799] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.753250] Bluetooth: hci0: Waiting for firmware download to complete
[ 7.753804] Bluetooth: hci0: Firmware loaded in 1543305 usecs
[ 7.754041] Bluetooth: hci0: Waiting for device to boot
[ 7.766875] Bluetooth: hci0: Device booted in 12602 usecs
[ 7.816306] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 7.818940] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 10.508066] wlan0: authenticate with 58:96:30:01:74:cd
[ 10.517971] wlan0: send auth to 58:96:30:01:74:cd (try 1/3)
[ 10.526605] wlan0: authenticated
[ 10.530824] wlan0: associate with 58:96:30:01:74:cd (try 1/3)
[ 10.535510] wlan0: RX AssocResp from 58:96:30:01:74:cd (capab=0x1511 status=0 aid=8)
[ 10.537162] wlan0: associated
[ 10.567529] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 10.680821] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 58:96:30:01:74:cd
[ 13.214111] tegradc tegradc.0: blank - powerdown
[ 13.265262] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 13.265264] Extcon AUX1(HDMI) disable
[ 13.285662] tegradc tegradc.0: unblank
[ 13.296128] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 13.296208] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 13.297227] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 13.297235] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 13.332866] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 13.332869] Extcon AUX1(HDMI) enable
[ 13.339017] tegradc tegradc.0: unblank
[ 13.339236] tegradc tegradc.1: blank - powerdown
[ 14.702119] fuse init (API version 7.26)
[ 30.460634] tegradc tegradc.0: blank - powerdown
[ 30.515056] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 30.515068] Extcon AUX1(HDMI) disable
[ 30.534966] tegradc tegradc.1: blank - powerdown
[ 33.677260] tegradc tegradc.0: blank - powerdown
[ 33.677281] tegradc tegradc.0: unblank
[ 33.682028] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 33.682122] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 33.683159] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 33.683166] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 33.718161] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 33.718163] Extcon AUX1(HDMI) enable
[ 33.727380] tegradc tegradc.0: unblank
[ 33.727390] tegradc tegradc.1: blank - powerdown
[ 37.619022] tegradc tegradc.0: unblank
[ 37.619032] tegradc tegradc.1: blank - powerdown
Thanks a lot
