Hi, I’m thinking of buying a “12MP IMX477 Motorized IR-CUT Camera Module” to upgrade the setup I have with a previous 5MP camera module with IR cut filter. I have read this article regarding older versions that can be modified for control of the IR cut filter via GPIO: https://www.arducam.com/docs/cameras-for-raspberry-pi/noir-camera/
Is this possible also on the “12MP IMX477 Motorized IR-CUT Camera Module”?
The header pins for GND and IR are visible on the block diagram, so does this work the same as on the older modules, remove the photoresistor and weld a 470 ohm resistor (where in this case?)?
Thanks.
