Hello ArduCam Team,
- Amazon
- B0279
- Jetson Nano R32 6.1
- Problems you were having?
- Using the Nvidia driver
$ gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! "video/x-raw(memory:NVMM),width=400,height=400,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:725 No cameras available
Got EOS from element "pipeline0".
Execution ended after 0:00:00.001558744
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
- IMX477 is on
cam0
port of the Jetson Nano
$ dmesg | grep imx477
[ 1.304736] imx477 7-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.606520] imx477 8-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.906886] imx477 8-001a: imx477_board_setup: error during i2c read probe (-121)
[ 1.914482] imx477 8-001a: board setup failed
[ 1.918946] imx477: probe of 8-001a failed with error -121
[ 2.174493] vi 54080000.vi: subdev imx477 7-001a bound
- Please see below
- What help do you need?
When using your ArduCam “Automatic driver installation” (cannot link it, since new users are limited to two links?!), the camera works perfect, however after this installation previously initialized GPIO pins are being reset as stated in my post at NVIDIA (please see above), but I need the SPI pins
- I initialize SPI using
sudo /opt/nvidia/jetson-io/jetson-io.py
, reboot, works fine - Then I run
./install_full.sh -m imx477
, after reboot, the camera works, but the SPI is (“overwritten?”) reset
Therefore, I would like to use the Nvidia driver. I set up the CSI port according to your tutorial “IMX477 – How to install the Driver” (not allowed to put more links), using
. After reboot, my config for both SPI and CSI ports are good. -
Now the camera doesnt work anymore
Tried this with and without running
sudo dpkg -r arducam-nvidia-l4t-kernel
after initializing CSI usingsudo /opt/nvidia/jetson-io/jetson-io.py
Error is the same as above:
Can you tell me what I might be doing wrong here?
