Amazon
- IMX477 IR-CUT (SKU: B0274)
- Nvidia Jetson Nano B01 development board
R32 (release), REVISION: 7.2, GCID: 30192233, BOARD: t210ref, EABI: aarch64, DATE: Wed Apr 20 21:34:48 UTC 2022
Quick Start Guide
Step 1. Download the bash scripts
cd ~
Step 2. Install the driver
chmod +x install_full.sh
./install_full.sh -m imx477
5. Problems you were having?
Driver installation produces the following error:
Unpacking arducam-nvidia-l4t-kernel (4.9.253-tegra-32.7.2-20220517094150) over (4.9.253-tegra-32.7.2-20220517094150) ...
Setting up arducam-nvidia-l4t-kernel (4.9.253-tegra-32.7.2-20220517094150) ...
File "/opt/arducam/jetson-io/config-by-hardware.py", line 125, in <module>
main()
File "/opt/arducam/jetson-io/config-by-hardware.py", line 94, in main
jetson = board.Board()
File "/opt/arducam/jetson-io/Jetson/board.py", line 223, in __init__
self.appdir = _board_partition_mount('APP')
File "/opt/arducam/jetson-io/Jetson/board.py", line 156, in _board_partition_mount
raise RuntimeError("No %s partition found!" % partlabel)
RuntimeError: No APP partition found!
Jetson Nano CSI Connector not found.
main()
2
dpkg: error processing package arducam-nvidia-l4t-kernel (--install):
Unknown error, please send the error message to [email protected]
Running "dmesg | grep -E “imx477|imx219|arducam” :
[ 1.776057] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.799497] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.807155] imx219 7-0010: board setup failed
[ 1.811616] imx219: probe of 7-0010 failed with error -121
[ 1.812224] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.835598] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.843171] imx219 8-0010: board setup failed
[ 1.847612] imx219: probe of 8-0010 failed with error -121
1: ls /dev/video* → ls: cannot access ‘/dev/video*’: No such file or directory
2: Check camera wire connection
3: Tried camera on raspberry pi and it works
8. What help do you need?
Please help me get the driver working
