Amazon.com UCTRONICS -
Board says “Arducam UC-698 Rev. A” on silk -
I have a Jetson Xavier NX, 8GB RAM, 16GB EMMC, 512MB SSD
installed on a Seeed A203v2 carrier board (with one MIPI-CSI port).
It is a fresh build of JetPack 5.0.2, L4T 35.0.1
Ubuntu 20.04.6 LTS
Kernel version 5.10.104-tegra
Followed regular setup to flash OS onto Jetson Xavier per Seeed A203v2 instructions. -
using “sudo dmesg | grep imx477” at the terminal:
[ 11.469692] imx477 2-001a: tegracam sensor driver:imx477_v2.0.6
[ 11.793484] imx477 2-001a: imx477_board_setup: error during i2c read probe (-121)
[ 11.795739] imx477 2-001a: board setup failed
[ 11.801373] imx477: probe of 2-001a failed with error -121 -
see above - I get this message whether the ribbon cable/camera is connected or not. -
This hardware unit may be the one marketed on Amazon for Raspberry Pi versus the one marketed for Jetson Xavier (I have ordered both in the past and don’t know how to tell them apart visually. I only have one that I can find at the moment, and it might be the RPi version).
a. How can I tell (visually or otherwise) if the UC-698 is the Pi or Jetson product?
b. Can the Pi version be used with a Jetson Xavier?
c. What do the dmesg imx477 errors above mean, and can anyone suggest de-bugging steps?
d. Has anyone had success with an IMX477 product with M12 lens mount on the Jetson Xavier NX w/ A203v2 carrier board?
