IMX477 B0274 driver install fails: cannot find deb package on Jetson Nano
Hi everyone, I’m trying to install the driver for my IMX477 IR Cut Camera (B0274) on my Jetson Nano and it keeps failing with this error:
“Cannot find the corresponding deb package, please send the following information to [email protected]”
Has anyone run into this before? Not sure what I’m doing wrong.
That error usually means the installer can’t match a driver package to your current system. Can you post your environment details? Specifically the kernel version and Jetson model, and if you have a screenshot of the JetPack/kernel info that would help too.
Sure, here’s what I’ve got:
  • Kernel version: 4.9.337-tegra-32.7.4-20230608212426
  • Jetson type: NVIDIA Jetson Nano Developer Kit
I was attempting to install the drivers for the IMX477 IR Cut Camera B0274 when the error appeared. I’ve attached a screenshot with the JetPack and kernel version details as well.
Thanks, that clears it up. The issue is that Arducam has not released the camera driver for L4T 32.7.4, which is what you’re running. The installer looks for a matching deb package, doesn’t find one for that L4T version, and throws that error.
The fix is to re-flash your Jetson Nano to one of the supported versions. You can check the supported version list here:
https://docs.arducam.com/Nvidia-Jetson-Camera/Introduction-to-Arducam-Jetson-Cameras/
You’ll need to burn a supported JetPack version first before attempting the camera driver install.
Okay, that makes sense. But I’m still not finding the actual process for installing the camera drivers after that. Can you point me to the right steps?
Right, the key is to first be on a supported JetPack/L4T version. Once you’ve re-flashed, the driver install steps are in the Native Camera Quick Start Guide here:
https://docs.arducam.com/Nvidia-Jetson-Camera/Native-Camera/Quick-Start-Guide/#install-driver
So the flow is: burn a supported JetPack version, then follow the install-driver section in that guide.
Got it, thanks. One more thing though - I need the process for installing a specific JetPack version on the Jetson Nano specifically. Everything I can find seems to be written for Jetson Xavier or Orin. Do you have steps for the Nano?
For flashing a JetPack version onto the Jetson Nano, you’ll want to use the NVIDIA SDK Manager. It covers the Nano as well, even though a lot of tutorials focus on Xavier/Orin. Follow the NVIDIA guide here:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
To summarize the current conclusion: the original error happened because L4T 32.7.4 isn’t supported by the Arducam camera driver, so there was no matching deb package. The workaround is to flash a supported JetPack version onto the Nano using NVIDIA SDK Manager, then run the camera driver install steps from the Native Camera Quick Start Guide.
