Amazon
PCB says UC517 revD
CAM1 connector on the RasPI CM4
Mostly
I am using the IMX477 Autofocus module connected to a RasPI CM4 module on a custom motherboard that duplicates the CAM1 interface. The camera itself streams OK using gstreamer (which will be the end application). I am using the C-based autofocus library provided by ArduCAM in parallel with gstreamer. I am only running the manualFocusThread() part (without the thread) and removed raspistill to avoid the camera conflict wile running gstreamer.
What happens is that the combination works for a few seconds (I can see the focus adjust based on the keyboard input in the streamed video). After a few seconds, the video freezes and I cannot access the camera again until I do a hard power cycle (a restart of the system does not work).
When I try to run raspistill on the camera (with neither gstreamer nor the manualFocus program running) after the crash, I get this error:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn’t be enabled
mmal: Failed to run camera app. Please check for firmware updates
Internet search and examining AF program
Help understand and solve problem
