# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=68
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
dtoverlay=vc4-fkms-v3d
arm_boost=1
gpu_mem=128
dtoverlay=arducam-pivariety
camera="libcamera"
Hi @MrSpace
I have no idea why I could not reply on the forum yesterday.
I don’t think so. This camera module is truly compatible with Raspberry Pi Zero. Are you comfortable getting remote support? If the answer is positive, please send a private message to me.
