I need to capture video from a camera in a resolution of 1920x1080 with the highest possible frame rate, and then work with the resulting image in opencv.
Using arducamstill I get the maximum possible 60 FPS, however when using capture2opencv the frame rate is about 10 FPS.
To understand why this is happening, I wrote a small project based on capture2opencv, where I simply get an image from the camera and write it to cv::Mat using the get_image() function without displaying it through cv::imshow(). I measured the frame rate and got about 20 FPS.
I managed to figure out that this is happening because of the cv::cvtColor(*image, *image, cv::COLOR_YUV2BGR_I420) in the get_image() function. Removing this conversion, I get 16 ms to capture one frame, with it - 49 ms. Thus, on RPI4, this function takes 33 ms, which, in my opinion, is a very long time. Hence, the drop in the frame rate is exactly 3 times, since two frames are simply lost (I tried to depict it in the diagram).
It is due to the cvtColor function will do color convert which will need much time.
You can use the following code to get frame cap = cv2.VideoCapture(0,cv2.CAP_V4L2) ret, frame = cap.read()
Ok, how do I then capture the image from the camera as fast as possible? Taking into account the fact that in the future I need to work with him in OpenCV.
If you want to use opencv, the MIPI_Camera driver is not a good choice. For the imx298, you can cosider to work with our pivariety board, if using pivariety board, it use unicam driver which is basd on v4l2 framework. I think you can use opencv to grep the image through the video0 node. For more about this, please refer to Pivariety IMX298 16MP Motorized Focus Camera Module - Arducam
