Imx298 16 mp opencv python gst-launch-1.0
hello i don’t manage to get opencv work whith your doc helping
amazon
arducam pivariety imx298 16MP
raspberry pi 4 4go
Redirecting...
5. Problems you were having?
pi@raspberrypi:~ $ gst-launch-1.0 libcamerasrc ! ‘video/x-raw,width=1920,height=1080’ ! videoconvert ! tee ! v4l2sink device=/dev/video3
Définition du pipeline à PAUSED…
[0:02:20.506805809] [1033] INFO Camera camera_manager.cpp:296 libcamera v0.0.0+2736-579f55b1-dirty (2021-07-01T03:47:30-04:00)
[0:02:20.512779501] [1035] WARN CameraSensor camera_sensor.cpp:197 ‘arducam-pivariety 10-000c’: Recommended V4L2 control 0x009a0922 not supported
[0:02:20.526663732] [1035] WARN CameraSensor camera_sensor.cpp:249 ‘arducam-pivariety 10-000c’: The sensor kernel driver needs to be fixed
[0:02:20.526744335] [1035] WARN CameraSensor camera_sensor.cpp:251 ‘arducam-pivariety 10-000c’: See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:02:20.530254995] [1035] WARN CameraSensorProperties camera_sensor_properties.cpp:109 No static properties available for ‘arducam-pivariety’
[0:02:20.530340561] [1035] WARN CameraSensorProperties camera_sensor_properties.cpp:111 Please consider updating the camera sensor properties database
[0:02:20.530401389] [1035] WARN CameraSensor camera_sensor.cpp:403 ‘arducam-pivariety 10-000c’: Failed to retrieve the camera location
[0:02:20.777296357] [1035] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file ‘arducam-pivariety.json’ not found for IPA module ‘raspberrypi’
Le pipeline est actif et n’a pas besoin de phase PREROLL…
[0:02:21.170157966] [1038] WARN V4L2 v4l2_pixelformat.cpp:181 Unsupported V4L2 pixel format XB24
Passage du pipeline à la phase PLAYING…
New clock: GstSystemClock
** (gst-launch-1.0:1033): CRITICAL **: 21:45:30.682: gst_video_format_to_string: assertion ‘format != GST_VIDEO_FORMAT_UNKNOWN’ failed
[0:02:21.188266436] [1038] INFO Camera camera.cpp:906 configuring streams: (0) 1920x1080-NV21
[0:02:21.188688358] [1035] INFO RPI raspberrypi.cpp:128 Mode: 4640x3472 fmt RG10 Score: 4102.12 (best 4102.12)
[0:02:21.188802847] [1035] INFO RPI raspberrypi.cpp:128 Mode: 2320x1732 fmt RG10 Score: 3077.86 (best 3077.86)
[0:02:21.188872766] [1035] INFO RPI raspberrypi.cpp:128 Mode: 3264x2464 fmt RG10 Score: 3541.31 (best 3077.86)
[0:02:21.188941000] [1035] INFO RPI raspberrypi.cpp:128 Mode: 3840x2160 fmt RG10 Score: 2250 (best 2250)
[0:02:21.189003661] [1035] INFO RPI raspberrypi.cpp:128 Mode: 2592x1944 fmt RG10 Score: 3217.33 (best 2250)
[0:02:21.189069433] [1035] INFO RPI raspberrypi.cpp:128 Mode: 1920x1080 fmt RG10 Score: 1500 (best 1500)
[0:02:21.189132741] [1035] INFO RPI raspberrypi.cpp:128 Mode: 1280x800 fmt RG10 Score: 3873.33 (best 1500)
[0:02:21.189195902] [1035] INFO RPI raspberrypi.cpp:128 Mode: 1280x720 fmt RG10 Score: 3500 (best 1500)
[0:02:21.189292004] [1035] INFO RPI raspberrypi.cpp:128 Mode: 4640x3472 fmt pRAA Score: 3602.12 (best 1500)
[0:02:21.189357997] [1035] INFO RPI raspberrypi.cpp:128 Mode: 2320x1732 fmt pRAA Score: 2577.86 (best 1500)
[0:02:21.189420121] [1035] INFO RPI raspberrypi.cpp:128 Mode: 3264x2464 fmt pRAA Score: 3041.31 (best 1500)
[0:02:21.189484207] [1035] INFO RPI raspberrypi.cpp:128 Mode: 3840x2160 fmt pRAA Score: 1750 (best 1500)
[0:02:21.189545609] [1035] INFO RPI raspberrypi.cpp:128 Mode: 2592x1944 fmt pRAA Score: 2717.33 (best 1500)
[0:02:21.189609065] [1035] INFO RPI raspberrypi.cpp:128 Mode: 1920x1080 fmt pRAA Score: 1000 (best 1000)
[0:02:21.189669689] [1035] INFO RPI raspberrypi.cpp:128 Mode: 1280x800 fmt pRAA Score: 3373.33 (best 1000)
[0:02:21.189733424] [1035] INFO RPI raspberrypi.cpp:128 Mode: 1280x720 fmt pRAA Score: 3000 (best 1000)
[0:02:21.244174843] [1035] INFO RPI raspberrypi.cpp:625 Sensor: /base/soc/i2c0mux/i2c@1/arducam@0c - Selected mode: 1920x1080-pRAA
[0:02:21.290109973] [1035] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:02:21.290190558] [1035] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:02:21.290245997] [1035] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:02:21.290298659] [1035] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:02:21.742576704] [1035] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (7 left)
[0:02:21.763751286] [1035] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (6 left)
[0:02:21.789800834] [1035] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (5 left)
[0:02:21.811948454] [1035] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (4 left)
[0:02:21.832797547] [1035] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (3 left)
[0:02:21.853507468] [1035] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (2 left)
[0:02:21.875114343] [1035] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (1 left)
[0:02:21.908638984] [1035] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (0 left)
and when i use your scipt on another console while the first run to test opencv :
import cv2
cap = cv2.VideoCapture(3)
while True:
ret, frame = cap.read()
cv2.imshow(“Arducam”, frame)
key = cv2.waitKey(1)
if key == ord(‘q’):
break
the response is :
VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
OpenCV Error: Assertion failed (size.width>0 && size.height>0) in imshow, file /build/opencv-L65chJ/opencv-3.2.0+dfsg/modules/highgui/src/window.cpp, line 304
File “test.py”, line 5, in
cv2.error: /build/opencv-L65chJ/opencv-3.2.0+dfsg/modules/highgui/src/window.cpp:304: error: (-215) size.width>0 && size.height>0 in function imshow
I don’t manage to make it work
Could you please explain me what i do wrong and how to solve it ?
thanks a lot
Hi tityann
We encapsulate the Libcamera Python library, you can try to use this library to operate the camera.
Download libcamera python library URL
hello @yang
thanks you it work fine
can you please tell me how to do the same as
libcamera-still -t 0 --autofocus
with libcamera and python ?
thanks
Hi tityann
Sorry, I only see your question now.
You can add the following code in the controls_demo.py example to the place shown in the figure below:
elif key == ord('f'):
        cam.set(libcamera.AfTrigger, 1)
Screenshot from 2021-11-05 09-39-38
In this way, you can press “f” to auto focus.
