IMX219
Jetson Xavier NX
Yes, it was working. Then, I quit working.
When I’m trying to run the command “gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink”, I’m getting the error:
"Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:645 No cameras available
(gst-launch-1.0:10465): GStreamer-CRITICAL **: 08:47:24.453: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed"
The camera seems to be visible as “/dev/video0” when I run the command “ls /dev”
Can you help me to solve the issue? Thank you in advance.
