The software of the USB 2 shield is not compatible with RaspberryPi IMX219. Can you tell me your email? I can send you a specific version of the GUI app.
color mode 2 Traceback (most recent call last): File “MyPrograms\Streaming_demo\ArduCam_Py_Demo.py”, line 198, in <module> if camera_initFromFile(config_file_name): File “MyPrograms\Streaming_demo\ArduCam_Py_Demo.py”, line 85, in camera_initFromFile ArducamSDK.Py_ArduCam_registerCtrls(handle, config.controls, config.controls_length) File “pyArducam.pyx”, line 767, in ArducamSDK.Py_ArduCam_registerCtrls ValueError: NULL pointer access
Python programing goes well now. Changing registersetting on imx219 is responding as expected. Except for changing the width of the image, I can only setting the values (1920, 3280) as in the cfg files.
For my application (planetary astro camera) I need to set small resolutions with high framerate.
Is it possible to change the image size to 480x320 pix, or something like that?
Sorry for the late reply, we currently don’t have a similar configuration. It will take some time to create a new configuration because our engineers are busy.
By the way, why do you need a 480×320 resolution, is 640x480 enough for you?
I need to be able to select a small ‘Region Of Intrest’ on the 3280x2462 sized sensor, in order to decrease amount of output data and increase the framerate.
High framerate and short exposuretime is necesarry in a planetary camera to frees atmospheric turbuence.
Hi, I also have USB device create error with IMX219 on USB 2 shield UC-391 Rev E . The camera board is UC-350 Rev C, and on the box it is written B0102. Please also send me the SDK. Thanks
B0102 was not originally designed to work with USB shields. So our officially released version of the SDK does not support it. If you want to use it, we can send you a specific version of the SDK.
Please provide your email if you need it.
