IMX219 camera detected as /dev/video0 on Jetson Xavier but gst-launch says no camera found
Hi, I’m having trouble with an Arducam IMX219 camera on a Jetson Xavier. The camera is detected as /dev/video0 but any time I try to get it to work with gst-launch I get an error saying there’s no camera found. I never got it to work. Attaching a couple of photos of the camera (front and back). Any idea what’s going on?
Hi, thanks for the detailed post and the pictures — front and back shots of the camera are always helpful. So to recap: the IMX219 is showing up as /dev/video0 on your Jetson Xavier, but gst-launch reports no camera found. That points to a driver/detection question rather than a wiring problem.
First thing we want to confirm is whether the driver was actually installed correctly. Can you run:
ls /dev/video*
and paste the output so we can see exactly which video devices are enumerated? In the meantime, please have a look at our IMX477/IMX219 troubleshooting doc here:
https://www.arducam.com/docs/camera-for-jetson-nano/native-jetson-cameras-imx219-imx477/imx477-troubleshoot/
Let us know what you get.
Hey, the camera is detected as video0
Thanks for confirming — so it’s detected as video0, good. That tells us the device node exists, but it doesn’t tell us whether the IMX219 driver actually loaded. The next step is to check the kernel messages for the driver.
Please run:
dmesg | grep -E "imx477|imx219|arducam"
If you see messages about imx219 (or imx477 / arducam), then the driver is installed and we can dig into the gst-launch pipeline itself. If nothing comes back, we’ll know the driver isn’t loaded.
Either way, please send us a picture or paste the output of that command. Looking forward to your reply.
