what are the lens shading data used for? Can you explain a bit, please?
When I run the executable outside of the folder where it was compiled (I copy it to $HOME/bin) then the libarducam_mipicamera.so complains:
Can’t open the file
If I then link the lens_shading_table folder to that directory it works again. Is there a way for me to specify an absolute path to the lens_shading_table folder?
Can you elaborate on what the lens shading problems are? How do they distort the picture?
> The driver will find the file in the MIPI_Camera/tree/master/RPI/lens_shading_table/imx135
Yes, but this is a RELATIVE path to the current directory (working directory) I am in when I call the command to take a picture. Is there a way to make this an ABSOLUTE path so that the Ardu commands will work when called in any arbitrary directory? Can I specify this path either via API or via an environment variable?
> path, if it is not exist, it will use default mode.
Right. But how good is the default mode? I assume the lens_shading_table data are better than the default mode, or? So I would really like to be able to use these lens_shading_table data from anywhere. This is not possible as long as the path is a RELATIVE path to the directory from which I call the command. Please try to call, e.g., the arducamstill command from $HOME.
About lens shading problems, it is due to the mismatch between the lens and the sensor caused the image to be off-color. The principle of lens table generation is to make the image as uniform as possible by compensating the gain of pixels.
About the lens shading path, it just support relative paths, you can’t set it in special.
If the driver does not find the lens shading table, it will use the default mode, which means
the image is original image without gain compensation. In fact, due to without the official raspberrypi ISP support, the result of the lens shading is not very well.
