0.120114] raspberrypi-firmware soc:firmware: Firmware hash is 74a4b109e7f5be465332a1f102649d34f8498d05
[ 0.183751] Kprobes globally optimized
[ 0.189979] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.194771] vgaarb: loaded
[ 0.195257] SCSI subsystem initialized
[ 0.195494] usbcore: registered new interface driver usbfs
[ 0.195557] usbcore: registered new interface driver hub
[ 0.195630] usbcore: registered new device driver usb
[ 0.196059] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.196245] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.196596] pps_core: LinuxPPS API ver. 1 registered
[ 0.196611] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.196640] PTP clock support registered
[ 0.198459] clocksource: Switched to clocksource arch_sys_counter
[ 0.279235] VFS: Disk quotas dquot_6.6.0
[ 0.279341] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.279528] FS-Cache: Loaded
[ 0.279747] CacheFiles: Loaded
[ 0.280980] simple-framebuffer 3e2fd000.framebuffer: framebuffer at 0x3e2fd000, 0x8ca000 bytes
[ 0.281004] simple-framebuffer 3e2fd000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
[ 0.281586] Console: switching to colour frame buffer device 240x75
[ 0.293675] simple-framebuffer 3e2fd000.framebuffer: fb0: simplefb registered!
[ 0.303878] NET: Registered PF_INET protocol family
[ 0.304154] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.305818] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.305855] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.305880] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.305945] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.306025] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.306193] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.306234] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.306499] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.309412] RPC: Registered named UNIX socket transport module.
[ 0.309429] RPC: Registered udp transport module.
[ 0.309443] RPC: Registered tcp transport module.
[ 0.309457] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.309479] PCI: CLS 0 bytes, default 64
[ 1.340832] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.364251] Initialise system trusted keyrings
[ 1.364564] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 1.373736] zbud: loaded
[ 1.375772] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.376698] NFS: Registering the id_resolver key type
[ 1.376744] Key type id_resolver registered
[ 1.376759] Key type id_legacy registered
[ 1.376892] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.376909] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.378020] Key type asymmetric registered
[ 1.378037] Asymmetric key parser ‘x509’ registered
[ 1.378267] bounce: pool size: 64 pages
[ 1.378333] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.378612] io scheduler mq-deadline registered
[ 1.378631] io scheduler kyber registered
[ 1.387881] gpio-507 (ant1): hogged as output/high
[ 1.389326] gpio-511 (ant2): hogged as output/low
[ 1.391157] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.391195] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.391291] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.391384] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x007fffffff → 0x0400000000
[ 1.988483] brcm-pcie fd500000.pcie: link down
[ 2.002413] iproc-rng200 fe104000.rng: hwrng registered
[ 2.002819] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 2.004514] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 2.017874] brd: module loaded
[ 2.028638] loop: module loaded
[ 2.029534] Loading iSCSI transport class v2.0-870.
[ 2.035022] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 2.128620] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 2.129908] usbcore: registered new interface driver r8152
[ 2.129983] usbcore: registered new interface driver lan78xx
[ 2.130046] usbcore: registered new interface driver smsc95xx
[ 2.156186] xhci-hcd fe9c0000.xhci: xHCI Host Controller
[ 2.156236] xhci-hcd fe9c0000.xhci: new USB bus registered, assigned bus number 1
[ 2.158737] xhci-hcd fe9c0000.xhci: hcc params 0x0220fe65 hci version 0x110 quirks 0x0000000000010010
[ 2.158854] xhci-hcd fe9c0000.xhci: irq 78, io mem 0xfe9c0000
[ 2.159140] xhci-hcd fe9c0000.xhci: xHCI Host Controller
[ 2.159167] xhci-hcd fe9c0000.xhci: new USB bus registered, assigned bus number 2
[ 2.159193] xhci-hcd fe9c0000.xhci: Host supports USB 3.0 SuperSpeed
[ 2.159558] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.159581] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.159601] usb usb1: Product: xHCI Host Controller
[ 2.159618] usb usb1: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
[ 2.159634] usb usb1: SerialNumber: fe9c0000.xhci
[ 2.160359] hub 1-0:1.0: USB hub found
[ 2.160429] hub 1-0:1.0: 1 port detected
[ 2.161095] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.161399] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 2.161421] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.161439] usb usb2: Product: xHCI Host Controller
[ 2.161456] usb usb2: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
[ 2.161472] usb usb2: SerialNumber: fe9c0000.xhci
[ 2.162123] hub 2-0:1.0: USB hub found
[ 2.162191] hub 2-0:1.0: config failed, hub doesn’t have any ports! (err -19)
[ 2.162845] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.163283] dwc_otg: FIQ enabled
[ 2.163297] dwc_otg: NAK holdoff enabled
[ 2.163311] dwc_otg: FIQ split-transaction FSM enabled
[ 2.163329] Module dwc_common_port init
[ 2.163817] usbcore: registered new interface driver uas
[ 2.163925] usbcore: registered new interface driver usb-storage
[ 2.164160] mousedev: PS/2 mouse device common for all mice
[ 2.169828] sdhci: Secure Digital Host Controller Interface driver
[ 2.169844] sdhci: Copyright(c) Pierre Ossman
[ 2.170649] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.174702] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.175046] hid: raw HID events driver (C) Jiri Kosina
[ 2.175247] usbcore: registered new interface driver usbhid
[ 2.175263] usbhid: USB HID core driver
[ 2.182006] Initializing XFRM netlink socket
[ 2.182055] NET: Registered PF_PACKET protocol family
[ 2.182189] Key type dns_resolver registered
[ 2.182725] Registering SWP/SWPB emulation handler
[ 2.183570] registered taskstats version 1
[ 2.183616] Loading compiled-in X.509 certificates
[ 2.184509] Key type .fscrypt registered
[ 2.184525] Key type fscrypt-provisioning registered
[ 2.197395] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 2.197713] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 2.197854] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 2.207364] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.207868] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.209235] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.209258] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 2.239502] of_cfs_init
[ 2.239804] of_cfs_init: OK
[ 2.275285] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 2.275706] Waiting for root device PARTUUID=c14b8e8c-02…
[ 2.328203] mmc1: new high speed SDIO card at address 0001
[ 2.342452] mmc0: new DDR MMC card at address 0001
[ 2.343532] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 2.346884] mmcblk0: p1 p2
[ 2.347455] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 2.347976] mmcblk0boot0: mmc0:0001 8GTF4R 4.00 MiB
[ 2.350726] mmcblk0boot1: mmc0:0001 8GTF4R 4.00 MiB
[ 2.353083] mmcblk0rpmb: mmc0:0001 8GTF4R 512 KiB, chardev (242:0)
[ 2.364610] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 2.364693] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.365221] devtmpfs: mounted
[ 2.376516] Freeing unused kernel image (initmem) memory: 2048K
[ 2.398798] Run /sbin/init as init process
[ 2.398815] with arguments:
[ 2.398828] /sbin/init
[ 2.398841] splash
[ 2.398854] with environment:
[ 2.398866] HOME=/
[ 2.398879] TERM=linux
[ 2.448579] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 2.608779] systemd[1]: System time before build time, advancing clock.
[ 2.628958] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 2.628988] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.629008] usb 1-1: Product: USB 2.0 Hub
[ 2.671592] hub 1-1:1.0: USB hub found
[ 2.671718] hub 1-1:1.0: 4 ports detected
[ 2.791118] NET: Registered PF_INET6 protocol family
[ 2.792896] Segment Routing with IPv6
[ 2.792941] In-situ OAM (IOAM) with IPv6
[ 2.856606] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.857543] systemd[1]: Detected architecture arm.
[ 2.859068] systemd[1]: Set hostname to .
[ 3.098521] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
[ 3.343965] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00
[ 3.344000] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.344020] usb 1-1.1: Product: USB Keyboard
[ 3.344038] usb 1-1.1: Manufacturer: Logitech
[ 3.471663] input: Logitech USB Keyboard as /devices/platform/scb/fe9c0000.xhci/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C31C.0001/input/input0
[ 3.539482] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-fe9c0000.xhci-1.1/input0
[ 3.567511] input: Logitech USB Keyboard Consumer Control as /devices/platform/scb/fe9c0000.xhci/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C31C.0002/input/input1
[ 3.595595] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.628901] input: Logitech USB Keyboard System Control as /devices/platform/scb/fe9c0000.xhci/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C31C.0002/input/input2
[ 3.629266] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-fe9c0000.xhci-1.1/input1
[ 3.778578] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.783559] systemd[1]: Created slice system-getty.slice.
[ 3.784939] systemd[1]: Created slice system-modprobe.slice.
[ 3.786017] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.786885] systemd[1]: Created slice User and Session Slice.
[ 3.787453] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.788950] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.789635] systemd[1]: Reached target Slices.
[ 3.789855] systemd[1]: Reached target Swap.
[ 3.790998] systemd[1]: Listening on Syslog Socket.
[ 3.791742] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.792158] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.793339] systemd[1]: Listening on Journal Audit Socket.
[ 3.794101] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.795057] systemd[1]: Listening on Journal Socket.
[ 3.796703] systemd[1]: Listening on udev Control Socket.
[ 3.797542] systemd[1]: Listening on udev Kernel Socket.
[ 3.798537] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.804267] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.811180] systemd[1]: Mounting RPC Pipe File System…
[ 3.818505] systemd[1]: Mounting Kernel Debug File System…
[ 3.826781] systemd[1]: Mounting Kernel Trace File System…
[ 3.827485] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.828683] usb 1-1.2: new low-speed USB device number 4 using xhci-hcd
[ 3.839306] systemd[1]: Starting Restore / save the current clock…
[ 3.848264] systemd[1]: Starting Set the console keyboard layout…
[ 3.857203] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.866174] systemd[1]: Starting Load Kernel Module configfs…
[ 3.876278] systemd[1]: Starting Load Kernel Module drm…
[ 3.884590] systemd[1]: Starting Load Kernel Module fuse…
[ 3.888737] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.896044] systemd[1]: Starting File System Check on Root Device…
[ 3.912680] systemd[1]: Starting Journal Service…
[ 3.942033] systemd[1]: Starting Load Kernel Modules…
[ 3.961021] systemd[1]: Starting Coldplug All udev Devices…
[ 3.986710] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.987621] systemd[1]: Mounted RPC Pipe File System.
[ 3.988358] systemd[1]: Mounted Kernel Debug File System.
[ 3.989229] systemd[1]: Mounted Kernel Trace File System.
[ 3.991429] systemd[1]: Finished Restore / save the current clock.
[ 3.997108] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.999644] systemd[1]: [email protected]: Succeeded.
[ 4.001299] systemd[1]: Finished Load Kernel Module configfs.
[ 4.011024] systemd[1]: Mounting Kernel Configuration File System…
[ 4.016509] i2c_dev: i2c /dev entries driver
[ 4.018031] fuse: init (API version 7.34)
[ 4.021784] systemd[1]: Started File System Check Daemon to report status.
[ 4.026073] systemd[1]: [email protected]: Succeeded.
[ 4.027985] systemd[1]: Finished Load Kernel Module fuse.
[ 4.040313] systemd[1]: Finished Load Kernel Modules.
[ 4.063910] systemd[1]: Mounting FUSE Control File System…
[ 4.073358] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c016, bcdDevice= 3.40
[ 4.073396] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.073419] usb 1-1.2: Product: Optical USB Mouse
[ 4.073436] usb 1-1.2: Manufacturer: Logitech
[ 4.099042] systemd[1]: Starting Apply Kernel Variables…
[ 4.111501] systemd[1]: Mounted Kernel Configuration File System.
[ 4.127124] systemd[1]: Mounted FUSE Control File System.
[ 4.143572] input: Logitech Optical USB Mouse as /devices/platform/scb/fe9c0000.xhci/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C016.0003/input/input3
[ 4.144194] hid-generic 0003:046D:C016.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-fe9c0000.xhci-1.2/input0
[ 4.203879] systemd[1]: Finished File System Check on Root Device.
[ 4.210911] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 4.219936] systemd[1]: Finished Apply Kernel Variables.
[ 4.224431] systemd[1]: [email protected]: Succeeded.
[ 4.227537] systemd[1]: Finished Load Kernel Module drm.
[ 4.337444] systemd[1]: Started Journal Service.
[ 4.414282] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 4.486904] systemd-journald[141]: Received client request to flush runtime journal.
[ 4.497239] systemd-journald[141]: File /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.615551] usb 1-1.1: reset low-speed USB device number 3 using xhci-hcd
[ 5.766493] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.768769] mc: Linux media interface: v0.10
[ 5.808076] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.816964] bcm2835_audio bcm2835_audio: there is not valid maps for state default
[ 5.940885] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.940923] [vc_sm_connected_init]: start
[ 5.944441] [vc_sm_connected_init]: installed successfully
[ 6.078810] videodev: Linux video capture interface: v2.00
[ 6.164958] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 6.184972] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 6.293794] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.351919] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.366045] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.376042] checking generic (3e2fd000 8ca000) vs hw (0 ffffffffffffffff)
[ 6.376087] fb0: switching to vc4 from simple
[ 6.406274] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.409251] Console: switching to colour dummy device 80x30
[ 6.448918] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.448974] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.460742] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.462833] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.462902] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.473121] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.473171] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.474992] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.480256] Registered IR keymap rc-cec
[ 6.480451] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.480777] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input4
[ 6.484456] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.484505] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.486313] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.491635] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.491684] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 6.494681] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.497863] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.505484] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.505535] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.505571] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.505597] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.505621] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.523521] Registered IR keymap rc-cec
[ 6.523720] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 6.523960] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input5
[ 6.524486] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.525067] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.527458] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.528001] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.528036] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.528074] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.528103] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.528135] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.544928] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.563237] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.674758] i2c 0-001a: Fixing up cyclic dependency with fe800000.csi
[ 6.675186] i2c i2c-22: Added multiplexed i2c bus 0
[ 6.676389] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[ 6.676788] i2c i2c-22: Added multiplexed i2c bus 10
[ 6.676851] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.677471] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 6.677956] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.678502] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.678955] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.679390] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.679821] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.786358] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 6.876372] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.958725] rpivid feb10000.codec: Device registered as /dev/video19
[ 6.980278] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 7.034145] Console: switching to colour frame buffer device 240x75
[ 7.034225] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 7.282580] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.338951] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 7.346053] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.862737] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.918610] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.920651] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-compute-module.bin failed with error -2
[ 7.949989] uart-pl011 fe201000.serial: no DMA platform data
[ 8.214793] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.214986] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.220685] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 8.248839] usbcore: registered new interface driver brcmfmac
[ 8.345046] 8021q: 802.1Q VLAN Support v1.8
[ 8.578142] Adding 102396k swap on /var/swap. Priority:-2 extents:2 across:110588k SSFS
[ 8.591321] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 8.593970] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.581035] dw9807_vcm: loading out-of-tree module taints kernel.
[ 10.639306] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 10.639546] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.665412] dw9807 10-000c: I2C write CTL fail ret = -121
[ 10.678158] arducam_64mp 0-001a: Device found Arducam 64MP.
[ 10.685801] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 10.685841] dw9807 10-000c: dw9807_standby I2C failure: -121
[ 10.687270] dw9807 10-000c: I2C write CTL fail ret = -121
[ 10.687978] arducam_64mp 0-001a: Consider updating driver arducam_64mp to match on endpoints
[ 10.718471] dw9807 10-000c: I2C write CTL fail ret = -121
[ 10.734756] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[ 10.747717] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 10.751471] dw9807 10-000c: I2C write CTL fail ret = -121
[ 10.752865] arducam_64mp: probe of 10-001a failed with error -5
[ 10.949612] dw9807 10-000c: I2C write CTL fail ret = -121
[ 10.954196] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 10.955712] dw9807 10-000c: I2C write CTL fail ret = -121
[ 11.075170] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 12.291216] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[ 12.478498] hwmon hwmon1: Undervoltage detected!
[ 14.558512] hwmon hwmon1: Voltage normalised
[ 15.432668] Bluetooth: Core ver 2.22
[ 15.432740] NET: Registered PF_BLUETOOTH protocol family
[ 15.432747] Bluetooth: HCI device and connection manager initialized
[ 15.433593] Bluetooth: HCI socket layer initialized
[ 15.433610] Bluetooth: L2CAP socket layer initialized
[ 15.433629] Bluetooth: SCO socket layer initialized
[ 15.444200] Bluetooth: HCI UART driver ver 2.3
[ 15.444218] Bluetooth: HCI UART protocol H4 registered
[ 15.444282] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 15.444492] Bluetooth: HCI UART protocol Broadcom registered
[ 15.625292] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.625309] Bluetooth: BNEP filters: protocol multicast
[ 15.625324] Bluetooth: BNEP socket layer initialized
[ 15.651397] NET: Registered PF_ALG protocol family
[ 15.685396] cryptd: max_cpu_qlen set to 1000
[ 15.872454] Bluetooth: RFCOMM TTY layer initialized
[ 15.872478] Bluetooth: RFCOMM socket layer initialized
[ 15.872498] Bluetooth: RFCOMM ver 1.11
[ 32.488503] cam-dummy-reg: disabling
[ 39.635555] dw9807 10-000c: I2C write CTL fail ret = -121
[ 39.680583] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 39.681763] dw9807 10-000c: I2C write CTL fail ret = -121
[ 74.877797] hwmon hwmon1: Undervoltage detected!
[ 76.957506] hwmon hwmon1: Voltage normalised
[ 88.452761] dw9807 10-000c: I2C write CTL fail ret = -121
[ 89.436458] hwmon hwmon1: Undervoltage detected!
[ 93.402560] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 93.404040] dw9807 10-000c: I2C write CTL fail ret = -121
[ 97.766084] hwmon hwmon1: Voltage normalised
[ 99.170700] dw9807 10-000c: I2C write CTL fail ret = -121
[ 99.836050] hwmon hwmon1: Undervoltage detected!
[ 410.003902] bcmgenet fd580000.ethernet eth0: Link is Down
[ 412.093888] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 701.174165] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 701.175604] dw9807 10-000c: I2C write CTL fail ret = -121
[ 705.132954] hwmon hwmon1: Voltage normalised
[ 707.312539] dw9807 10-000c: I2C write CTL fail ret = -121
[ 709.293097] hwmon hwmon1: Undervoltage detected!
[ 710.249536] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 710.250955] dw9807 10-000c: I2C write CTL fail ret = -121
[ 711.373155] hwmon hwmon1: Voltage normalised
[ 750.903629] dw9807 10-000c: I2C write CTL fail ret = -121
[ 752.974385] hwmon hwmon1: Undervoltage detected!
[ 753.853275] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 753.854685] dw9807 10-000c: I2C write CTL fail ret = -121
[ 757.134450] hwmon hwmon1: Voltage normalised
[ 883.022960] dw9807 10-000c: I2C write CTL fail ret = -121
[ 884.017695] hwmon hwmon1: Undervoltage detected!
[ 885.961035] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 885.962457] dw9807 10-000c: I2C write CTL fail ret = -121
[ 888.177717] hwmon hwmon1: Voltage normalised
pi@raspberrypi:~ $
