I recently purchased a stereo sync hat from you all and wired everything up. The cameras are unable to open. The following is the relevant bit of dmesg (full dmesg below).
[ 1.239134] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.239435] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.239439] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.239942] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.247812] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.247815] Extcon AUX1(HDMI) disable
[ 1.263234] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.263313] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.263342] imx219 7-0010: board setup failed
[ 1.263402] imx219: probe of 7-0010 failed with error -121
[ 1.263790] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.279722] tegradc tegradc.0: unblank
[ 1.287078] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.287161] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.287198] imx219 8-0010: board setup failed
[ 1.287283] imx219: probe of 8-0010 failed with error -121
I attempted to install the arducam drivers as I initially thought that was the issue. This resulted in a similar but different error (probe failed).
I would appreciate help with this issue. Thank you.
full dmesg:
[ 0.969079] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.969267] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.969353] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.969439] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.969549] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.969637] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.969723] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.969808] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.976026] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.977773] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.979719] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.980966] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.981318] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.982751] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.982981] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.983221] Adding domain tsec-pd to PM domain host1x-pd
[ 0.985624] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.986635] tsec 54500000.tsec: initialized
[ 0.988313] tsec 54100000.tsecb: initialized
[ 0.989034] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.992616] nvdec 54480000.nvdec: initialized
[ 0.993691] Adding domain vic03-pd to PM domain host1x-pd
[ 0.993874] Adding domain msenc-pd to PM domain host1x-pd
[ 0.994082] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.998421] falcon 54340000.vic: initialized
[ 0.999694] falcon 544c0000.nvenc: initialized
[ 1.001112] falcon 54380000.nvjpg: initialized
[ 1.005619] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.005662] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.005696] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.005879] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.005998] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.006003] tegra_cec 70015000.tegra_cec: probed
[ 1.006049] display board info: id 0x0, fab 0x0
[ 1.006131] generic_infoframe_type: 0x87
[ 1.006270] tegradc tegradc.0: DT parsed successfully
[ 1.006316] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.006873] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.010404] tegradc tegradc.0: probed
[ 1.015843] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.023012] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.024102] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.024112] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.024490] kfuse 7000fc00.kfuse: initialized
[ 1.026071] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.027112] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.028637] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.028655] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.029155] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.030849] vdd-gpu: applied init 1000000uV constraint
[ 1.030860] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.031325] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.036175] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.036352] No Device Node present for smmu client: serial8250 !!
[ 1.036365] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.036430] iommu: Adding device serial8250 to group 35
[ 1.039066] console [ttyS0] disabled
[ 1.039137] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.039242] console [ttyS0] enabled
[ 1.040184] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.040461] serial-tegra 70006200.serial: RX in PIO mode
[ 1.040546] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.041673] [drm] Initialized
[ 1.042878] Console: switching to colour frame buffer device 240x67
[ 1.043004] tegradc tegradc.0: fb registered
[ 1.050783] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.050847] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.051371] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.051386] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.053041] brd: module loaded
[ 1.058995] loop: module loaded
[ 1.059111] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.059228] tegra_profiler: auth: init
[ 1.060628] THERMAL EST: found 2 subdevs
[ 1.060638] THERMAL EST num_resources: 0
[ 1.060644] [THERMAL EST subdev 0]
[ 1.060652] [THERMAL EST subdev 1]
[ 1.061129] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.061133] THERMAL EST: thz register success.
[ 1.061289] THERMAL EST: end of probe, return err: 0
[ 1.062717] sd: No Scsi addr parsed to reserve index
[ 1.062760] hisi_sas: driver version v1.6
[ 1.068097] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.069312] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.069324] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.072494] libphy: Fixed MDIO Bus: probed
[ 1.073482] tun: Universal TUN/TAP device driver, 1.6
[ 1.073489] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 1.074596] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.074600] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.074659] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.074663] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.074713] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.074718] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.074773] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.074777] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.075997] PPP generic driver version 2.4.2
[ 1.076206] PPP BSD Compression module registered
[ 1.076215] PPP Deflate Compression module registered
[ 1.076258] PPP MPPE Compression module registered
[ 1.076266] NET: Registered protocol family 24
[ 1.076340] usbcore: registered new interface driver r8152
[ 1.076391] usbcore: registered new interface driver asix
[ 1.076443] usbcore: registered new interface driver ax88179_178a
[ 1.076480] usbcore: registered new interface driver cdc_ether
[ 1.076519] usbcore: registered new interface driver net1080
[ 1.076559] usbcore: registered new interface driver cdc_subset
[ 1.076603] usbcore: registered new interface driver zaurus
[ 1.076659] usbcore: registered new interface driver cdc_ncm
[ 1.076828] VFIO - User Level meta-driver version: 0.3
[ 1.077733] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.077738] Extcon AUX1(HDMI) enable
[ 1.078844] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.078885] ehci-pci: EHCI PCI platform driver
[ 1.078940] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.078956] ohci-pci: OHCI PCI platform driver
[ 1.078997] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.079002] ohci-platform: OHCI generic platform driver
[ 1.079101] tegradc tegradc.1: No lt-data, using default setting
[ 1.079142] tegradc tegradc.1: No hpd-gpio in DT
[ 1.079196] tegradc tegradc.1: DT parsed successfully
[ 1.079257] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.081004] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.085418] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.085988] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.087256] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9032000 id
[ 1.089661] usbcore: registered new interface driver uas
[ 1.089731] usbcore: registered new interface driver usb-storage
[ 1.089840] usbcore: registered new interface driver usbserial
[ 1.090029] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.090093] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.090123] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.090916] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.090981] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.091223] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.091231] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.091237] usb usb1: Product: xHCI Host Controller
[ 1.091243] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.091247] usb usb1: SerialNumber: 70090000.xusb
[ 1.092475] hub 1-0:1.0: USB hub found
[ 1.092523] hub 1-0:1.0: 5 ports detected
[ 1.092997] tegradc tegradc.1: probed
[ 1.093225] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.093240] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.093341] tegradc tegradc.1: fb registered
[ 1.093347] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.093457] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.093465] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.093471] usb usb2: Product: xHCI Host Controller
[ 1.093476] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.093480] usb usb2: SerialNumber: 70090000.xusb
[ 1.093998] hub 2-0:1.0: USB hub found
[ 1.094056] hub 2-0:1.0: 4 ports detected
[ 1.096570] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.096578] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.096610] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.096627] tegradc tegradc.1: blank - powerdown
[ 1.096650] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.096656] Extcon DP: HPD disabled
[ 1.096661] hpd: hpd_switch 0
[ 1.096666] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.096674] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.096681] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.098010] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.099358] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.099373] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.099390] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.099405] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.099430] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.104046] mousedev: PS/2 mouse device common for all mice
[ 1.104178] usbcore: registered new interface driver xpad
[ 1.110624] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.194029] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.209455] tegradc tegradc.0: blank - powerdown
[ 1.235070] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.237214] rtc rtc1: alarm rtc device
[ 1.237226] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.237243] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.237612] i2c /dev entries driver
[ 1.288783] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.291920] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.291926] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.292399] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.292416] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.292425] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.292565] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.292574] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.292581] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.292729] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.292739] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.292744] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.292925] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.293833] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.293885] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.293906] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.293923] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.293931] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.295114] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.295134] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.295338] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.295367] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.295848] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.295851] parse_throttle_dt_data: Num cap clks = 6
[ 1.295855] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.295870] parse_throttle_dt_data: clk=gpu type=4
[ 1.295897] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.295918] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.295939] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.295943] parse_throttle_dt_data: clk=emc type=3
[ 1.295951] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.296325] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.296428] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.296585] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.297053] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.297072] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.297493] FAN dev name: pwm-fan
[ 1.297583] FAN:gpio request success.
[ 1.297665] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.298011] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.298269] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.298278] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.298391] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.298395] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.298400] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.298405] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.298409] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.298412] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.298416] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.298420] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.298424] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.298427] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.299413] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.299823] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.300810] device-mapper: uevent: version 1.0.3
[ 1.301298] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
[ 1.306483] tegra210-cpufreq cpufreq: probe()…completed
[ 1.307268] sdhci: Secure Digital Host Controller Interface driver
[ 1.307270] sdhci: Copyright(c) Pierre Ossman
[ 1.307271] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.307753] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.308093] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.308218] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.312964] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.313464] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.314618] usbcore: registered new interface driver usbhid
[ 1.314620] usbhid: USB HID core driver
[ 1.316762] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.316926] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.318778] nvpmodel: initialized successfully
[ 1.319715] usbcore: registered new interface driver snd-usb-audio
[ 1.319768] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.319772] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.319790] iommu: Adding device snd-soc-dummy to group 36
[ 1.330907] OPE platform probe
[ 1.330992] OPE platform probe successful
[ 1.331017] OPE platform probe
[ 1.331118] OPE platform probe successful
[ 1.332106] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.332108] Extcon AUX1(HDMI) enable
[ 1.332463] tegradc tegradc.0: sync windows ret = 250
[ 1.354098] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.359203] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.359339] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.359467] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.359596] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.359723] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.359863] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.359988] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.360113] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.360241] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.360367] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.364417] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.364420] Extcon HDMI: HPD enabled
[ 1.364440] tegradc tegradc.0: hdmi: plugged
[ 1.371897] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.372296] u32 classifier
[ 1.372298] Actions configured
[ 1.372367] Initializing XFRM netlink socket
[ 1.373071] NET: Registered protocol family 10
[ 1.373709] NET: Registered protocol family 17
[ 1.373721] NET: Registered protocol family 15
[ 1.373794] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.373836] Bluetooth: RFCOMM socket layer initialized
[ 1.373847] Bluetooth: RFCOMM ver 1.11
[ 1.373852] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.373857] Bluetooth: HIDP socket layer initialized
[ 1.373876] 9pnet: Installing 9P2000 support
[ 1.373910] Key type dns_resolver registered
[ 1.374319] Registered cp15_barrier emulation handler
[ 1.374326] Registered setend emulation handler
[ 1.375347] registered taskstats version 1
[ 1.375882] Adding domain ve2-pd to PM domain host1x-pd
[ 1.376133] Adding domain ve-pd to PM domain host1x-pd
[ 1.378292] isp 54600000.isp: initialized
[ 1.379269] isp 54680000.isp: initialized
[ 1.389715] last reset is due to power on reset
[ 1.389720] KERNEL: PMC reset status reg: 0x0
[ 1.389798] BL: PMC reset status reg: 0x0
[ 1.389800] BL: PMIC poweroff Event Recorder: 0x40
[ 1.391343] clk_cbus_recalc_rate: no gbus parent
[ 1.391349] clk_cbus_round_rate: no gbus parent
[ 1.391352] clk_cbus_round_rate: no gbus parent
[ 1.391360] clk_cbus_recalc_rate: no gbus parent
[ 1.391460] clk_cbus_recalc_rate: no gbus parent
[ 1.391464] clk_cbus_round_rate: no gbus parent
[ 1.391466] clk_cbus_round_rate: no gbus parent
[ 1.391470] clk_cbus_recalc_rate: no gbus parent
[ 1.392172] tegra_dvfs: GPU-cap: registered
[ 1.392226] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.392229] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.392231] tegra dvfs: vdd-gpu: nominal 1038mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.393645] tegra_dvfs: vdd-gpu-vts: registered
[ 1.394351] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.394919] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.395401] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.411117] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.418867] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.427249] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:13 UTC (946688413)
[ 1.428317] vi 54080000.vi: vi_probe: ++
[ 1.431162] vi 54080000.vi: initialized
[ 1.433251] vi 54080000.vi: subdev nvcsi–2 bound
[ 1.433353] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.434929] Disable partitions left on by BL
[ 1.434933] disb
[ 1.434980] bwmgr: missing cdev-type property
[ 1.435072] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.435079] DRAM derating cdev registered.
[ 1.436107] vdd-fan: disabling
[ 1.436110] vdd-usb-vbus: disabling
[ 1.436113] vdd-usb-vbus2: disabling
[ 1.436123] vddio-sdmmc3-ap: disabling
[ 1.436213] avdd-io-edp-1v05: disabling
[ 1.436215] vdd-usb-hub-en: disabling
[ 1.436300] ALSA device list:
[ 1.436303] #0: tegra-hda at 0x70038000 irq 83
[ 1.436305] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.439453] Freeing unused kernel memory: 8576K
[ 1.452708] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.452714] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.452718] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.452721] usb 1-2: Manufacturer: Generic
[ 1.455212] hub 1-2:1.0: USB hub found
[ 1.456299] hub 1-2:1.0: 4 ports detected
[ 1.464062] Root device found: mmcblk0p1
[ 1.549136] mmc0: hw tuning done …
[ 1.549173] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[ 1.549506] mmcblk0: mmc0:59b4 SDU3 116 GiB
[ 1.552987] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.668802] Found dev node: /dev/mmcblk0p1
[ 1.703265] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.704029] Rootfs mounted over mmcblk0p1
[ 1.727616] Switching from initrd to actual rootfs
[ 1.754017] usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
[ 1.782598] usb 1-2.1: New USB device found, idVendor=413c, idProduct=2113
[ 1.782602] usb 1-2.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.782605] usb 1-2.1: Product: Dell KB216 Wired Keyboard
[ 1.787708] input: Dell KB216 Wired Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:413C:2113.0001/input/input2
[ 1.815000] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.846396] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-70090000.xusb-2.1/input0
[ 1.850730] input: Dell KB216 Wired Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.1/0003:413C:2113.0002/input/input3
[ 1.910153] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-70090000.xusb-2.1/input1
[ 1.921845] systemd[1]: System time before build time, advancing clock.
[ 1.948802] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.960860] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.979501] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.980247] systemd[1]: Detected architecture arm64.
[ 1.989962] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 2.002821] systemd[1]: Set hostname to <nano>.
[ 2.005974] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.017875] usb 1-2.3: New USB device found, idVendor=0461, idProduct=4d22
[ 2.017882] usb 1-2.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.017886] usb 1-2.3: Product: USB Optical Mouse
[ 2.020609] input: USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:0461:4D22.0003/input/input4
[ 2.020877] hid-generic 0003:0461:4D22.0003: input,hidraw2: USB HID v1.11 Mouse [USB Optical Mouse] on usb-70090000.xusb-2.3/input0
[ 2.070499] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -113.
[ 2.070505] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.119314] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.119324] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.228191] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.230258] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.248436] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.248467] systemd[1]: Reached target Swap.
[ 2.248644] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.248665] systemd[1]: Reached target User and Group Name Lookups.
[ 2.248831] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.250155] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.251763] systemd[1]: Created slice System Slice.
[ 2.252029] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.289048] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.336380] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.336388] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.336392] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.336396] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.336401] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.336423] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.336488] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.336648] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.336757] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.336780] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.336809] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.336828] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.336963] pci 0000:01:00.0: supports D1 D2
[ 2.336966] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.346097] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.346128] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.346133] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.346139] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.346157] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.346174] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.346181] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.346186] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.346191] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.346488] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.346493] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.346498] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.346582] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.346748] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.346766] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.361259] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.361349] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e7:5b:96 from device tree
[ 2.361858] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.361875] r8168 Copyright (C) 2017 Realtek NIC software team <[email protected]>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 2.434239] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.503605] systemd-journald[2044]: Received request to flush runtime journal from PID 1
[ 2.999382] using random self ethernet address
[ 3.023495] using random host ethernet address
[ 3.535489] random: crng init done
[ 3.538924] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.101907] Mass Storage Function, version: 2009/09/11
[ 4.101914] LUN: removable file: (no medium)
[ 4.108245] using random self ethernet address
[ 4.119069] using random host ethernet address
[ 4.199571] rndis0: HOST MAC 96:e7:00:88:bf:e4
[ 4.199832] rndis0: MAC 96:e7:00:88:bf:e5
[ 4.202666] usb0: HOST MAC 96:e7:00:88:bf:e6
[ 4.202893] usb0: MAC 96:e7:00:88:bf:e7
[ 4.202931] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.207117] l4tbr0: port 1(rndis0) entered blocking state
[ 4.207122] l4tbr0: port 1(rndis0) entered disabled state
[ 4.207712] device rndis0 entered promiscuous mode
[ 4.220852] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.225776] l4tbr0: port 2(usb0) entered blocking state
[ 4.225781] l4tbr0: port 2(usb0) entered disabled state
[ 4.226795] device usb0 entered promiscuous mode
[ 4.234958] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.916096] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.917177] eth0: 0xffffff800d56c000, 00:04:4b:e7:5b:96, IRQ 407
[ 5.011322] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.141545] zram: Added device: zram0
[ 5.145652] zram: Added device: zram1
[ 5.150290] zram: Added device: zram2
[ 5.162372] zram: Added device: zram3
[ 5.193242] zram0: detected capacity change from 0 to 518549504
[ 5.231326] Adding 506392k swap on /dev/zram0. Priority:5 extents:1 across:506392k SS
[ 5.239010] zram1: detected capacity change from 0 to 518549504
[ 5.255151] Adding 506392k swap on /dev/zram1. Priority:5 extents:1 across:506392k SS
[ 5.256796] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.256802] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.259948] zram2: detected capacity change from 0 to 518549504
[ 5.301302] Adding 506392k swap on /dev/zram2. Priority:5 extents:1 across:506392k SS
[ 5.308590] zram3: detected capacity change from 0 to 518549504
[ 5.321531] Adding 506392k swap on /dev/zram3. Priority:5 extents:1 across:506392k SS
[ 5.582389] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.611523] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.611530] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.611534] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.611538] usb 2-1: Manufacturer: Generic
[ 5.615126] hub 2-1:1.0: USB hub found
[ 5.615934] hub 2-1:1.0: 4 ports detected
[ 5.770002] usb 2-1: usb_suspend_both: status 0
[ 5.770150] usb usb2: usb_suspend_both: status 0
[ 6.919695] tegradc tegradc.0: unblank
[ 6.919947] tegradc tegradc.1: blank - powerdown
[ 9.114393] r8168: eth0: link up
[ 9.114449] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.145687] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.145698] Bluetooth: BNEP socket layer initialized
[ 10.600491] fuse init (API version 7.26)
[ 11.434381] tegradc tegradc.0: unblank
[ 11.434391] tegradc tegradc.1: blank - powerdown
From this I knew to download the driver located here:
Please let me know how I can resolve this.
