I am trying to write a python code to control Arducam 64MP autofocus on Pi zero (Bullseye OS). After I install the driver in the manual documentation, I found that picamera2 is deleted and only picamera library, So I used this code to see if the camera works:
from picamera import PiCamera
import time
camera = PiCamera()
camera.start_preview()
time.sleep(10)
camera.stop_preview()
An error occurs with PiCamera and it tell to enable camera with sudo raspi-config.
But after enable, my camera doesn’t work any more, even when using licamera-still to check.
What is the proper way to use this 64 MP autofocus camera with python then?
Thank you
First, you need to make the camera work with libcamera-still. Does the pi 0 work when you reboot it?
If not, you can re-burn the OS and install everything again.
Once you manage to access the camera with libcamera command, you can refer to the link below to use picamera2. https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/PiCamera2-User-Guide/
#!/usr/bin/python3
import time
picam2 = Picamera2()
picam2.start_preview(Preview.QTGL)
preview_config = picam2.create_preview_configuration()
picam2.start()
time.sleep(1)
picam2.set_controls({"AfMode": 1 ,"AfTrigger": 0})
# If your libcamera-dev version is 0.0.10, use the following code.
# AfMode Set the AF mode (manual, auto, continuous)
# For example, single focus: picam2.set_controls({"AfMode": 1 ,"AfTrigger": 0})
# continuous focus: picam2.set_controls({"AfMode": 2 ,"AfTrigger": 0})
time.sleep(5)
