brand new arducam site
64mp
RPI4b+
Linux 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
Install guide was great after a fresh 64bit PiOS install.
libcamera-vid -t 0 --inline -o udp://100.69.217.10:3333
Made DRM preview window
[1:27:22.111678382] [1202] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[1:27:22.117517423] [1204] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[1:27:22.117565052] [1204] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[1:27:22.117854142] [1204] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
Open i2c bus error: No such file or directory
[1:27:22.132318828] [1204] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[1:27:22.132916211] [1204] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[1:27:22.133107932] [1204] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media0 and ISP device /dev/media3
[1:27:22.133754519] [1202] INFO Camera camera.cpp:1029 configuring streams: (0) 640x480-YUV420
[1:27:22.134146608] [1204] INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 1280x720-SBGGR10_1X10 - Selected unicam format: 1280x720-pBAA
dmesg | grep cam
[ 7.244370] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 7.247920] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
[ 33.759597] cam-dummy-reg: disabling
I think I need to tell it the resolution? Can’t figure out how.
Is the bottom line video or camera or both? How can you tell what are video modes? Or do you just wing it?
[8:37:09.448770454] [1546] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[8:37:09.454826285] [1547] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[8:37:09.454910858] [1547] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[8:37:09.455331151] [1547] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[8:37:09.470568561] [1547] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[8:37:09.471303313] [1547] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[8:37:09.471575126] [1547] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media0 and ISP device /dev/media3
Available cameras
0 : arducam_64mp [9248x6944] (/base/soc/i2c0mux/i2c@1/arducam_64mp@1a)
Modes: 'SRGGB10_CSI2P' : 1280x720 1920x1080 2312x1736 3840x2160 4624x3472 9152x6944
libcamera-vid -t 0 --inline --height 1280 --width 720 -o udp://remoteipaddress:3333
[8:47:05.139995626] [1593] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[8:47:05.145839093] [1595] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[8:47:05.145886500] [1595] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[8:47:05.146178220] [1595] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[8:47:05.160745740] [1595] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[8:47:05.161437975] [1595] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[8:47:05.161821619] [1595] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media0 and ISP device /dev/media3
[8:47:05.173833533] [1593] INFO Camera camera.cpp:1029 configuring streams: (0) 720x1280-YUV420
[8:47:05.174251214] [1595] INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 2312x1736-SBGGR10_1X10 - Selected unicam format: 2312x1736-pBAA
