successfully accessed pivariety camera ,now I am trying to set camera property like Brightness ,Contrast,Exposure,and so on .if it is possible to access those properties via provided libcamera_cpp_demo-master.zip .
please provide me support to over come this issues. Thank in advance
You can refer to the code below to set the camera frame rate, brightness, contrast and exposure time parameters.
ControlList controls_;
int64_t frame_time = 1000000 / 30;
// Set frame rate
controls_.set(controls::FrameDurationLimits, { frame_time, frame_time });
// Adjust the brightness of the output images, in the range -1.0 to 1.0
controls_.set(controls::Brightness, 0.5);
// Adjust the contrast of the output image, where 1.0 = normal contrast
controls_.set(controls::Contrast, 1.5);
// Set the exposure time
controls_.set(controls::ExposureTime, 20000);
cam.set(controls_);
For other control items, you can refer to the link below.
Thank Yang,
I have an doubt regarding of FrameDurationTime , what’s mean by frame_time= 1000000/30 ,is that FramePerSecond or anything else.Kindly please give an clarification about FrameRate . Thank you in advance
