Hello, I’m having difficulty setting the exposure of a stereo HAT setup with imx219 cameras. I want to run a line in a python script (within 1_test.py) which allows a custom exposure time to be set. I’ve tried reading and writing with the register scripts but am having difficulty getting this to work. Can you help with this?
In order to help you. I need more detail information about your problem.which script you are using and where is it? If you want to set the exposure time manually, you should disable the auto exposure mode firstly. We provide software_auto_exposure(enable = True) API for use to enable and disable the auto exposure mode. You can refer to our test demo here https://github.com/ArduCAM/MIPI_Camera/blob/master/RPI/python/preview.py
Sorry for the double post as in the manual exposure control section I just saw your post here. I’m trying to change the 1_test.py script to see the exposure change difference. To do this, I’m changing the script that writes to the registers (the arudcam_camera.py script). It is in the MIPI camera under the jetson nano tab. Can I use the software_auto_exposure API for python applications on the Jetson Nano? I see this command in the rasberry pi scripts but not the python scripts for the nano.
