ArduCam 64MP Autofocus Quad-Camera Kit | MYBOTSHOP.DE, 374,95 € -
Four ArduCam 64Mp Autofocus cameras UC-923, M1305 S, 810 IMX written on board and chip
SKU: MBS-SES-256
GTIN: 0618455044205 -
RPI 4, Compute Module 4 -
https://www.arducam.com/downloads/64mp-autofocus-quad-camera-kit.pdf -
I have not been able to get the latest OS to detect cameras but the 01/28/2022 OS did detect cameras, i can see preview and shoot pictures. But this OS only detects all 4 cameras as 1 camera, would like to control them separately. -
[email protected]:~ $ dmesg | grep -E “imx477|imx219|arducam”
[ 8.922032] arducam_64mp 0-001a: failed to read chip id 682, with error -5
[ 8.935997] arducam_64mp: probe of 0-001a failed with error -5
[ 8.949747] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 8.967236] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints -
I tried for serveral days with different guides and trial and error what to write to the /boot/config.txt on latest RPI OS but couldnt even get it to detect cameras at all, eventually flashed CM4 with OS version described in offical product pdf and was able to get something to work. -
I need help getting the cameras detected separately on this older os. and getting things to work on latest RPI OS.
This is my boot config:
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
disable_overscan=1
[cm4]
otg_mode=1
dtoverlay=arducam_64mp
dtoverlay=arducam_64mp,cam0
dtoverlay=vc4-kms-v3d,cma-512
[pi4]
arm_boost=1
This is my System _related info:
[email protected]:~ $ uname -a
Linux raspberrypi 5.10.92-v7l+ #1514 SMP Mon Jan 17 17:38:03 GMT 2022 armv7l GNU/Linux
[email protected]:~ $ cat /etc/os-release
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL=
SUPPORT_URL=“”
BUG_REPORT_URL="
[email protected]:~ $ cat /proc/meminfo
MemTotal: 1916712 kB
MemFree: 1273260 kB
MemAvailable: 1563044 kB
Buffers: 20160 kB
Cached: 410588 kB
SwapCached: 0 kB
Active: 87396 kB
Inactive: 393524 kB
Active(anon): 776 kB
Inactive(anon): 125468 kB
Active(file): 86620 kB
Inactive(file): 268056 kB
Unevictable: 65128 kB
Mlocked: 16 kB
HighTotal: 1232896 kB
HighFree: 692104 kB
LowTotal: 683816 kB
LowFree: 581156 kB
SwapTotal: 102396 kB
SwapFree: 102396 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 115356 kB
Mapped: 138920 kB
Shmem: 76072 kB
KReclaimable: 16568 kB
Slab: 37400 kB
SReclaimable: 16568 kB
SUnreclaim: 20832 kB
KernelStack: 2000 kB
PageTables: 4856 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 1060752 kB
Committed_AS: 1158072 kB
VmallocTotal: 245760 kB
VmallocUsed: 5868 kB
VmallocChunk: 0 kB
Percpu: 576 kB
CmaTotal: 524288 kB
CmaFree: 480908 kB
[email protected]:~ $ cat /boot/config.txt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
DMT (computer monitor) modes
#hdmi_drive=2
no display
#config_hdmi_boost=4
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
This is a log i made to explain what i have done:
Hardware:
RPI4
Compute Module 4 (Arducam UC-512 Rev.D1)
SKU: MBS-SES-256
GTIN: 0618455044205
Software:
raspios bullseye
kernel 5.10.96-v7l+
- Flashed 01/28/2022 OS from raspery website
the same version that was used for the guide - Connected 4 cameras to hat and connected the hat to RPI4, CAM0
- Booted, DID NOT make RPI update
- Enabled SSH with raspi-config just in case
- Installed gnome-screenshot after which mouse and keybaord stopped working so i used ssh
- Followed the guide
until
[email protected]:~ $ libcamera-still --list-cameras
No cameras available!
After boot
After connecting hat to CAM1 and disconnecting USB hub to connect mouse and keyboard so i can use them then rebooting software was able to detect 1 camera.
[email protected]:~ $ dmesg | grep arducam
[ 8.169458] arducam_64mp: loading out-of-tree module taints kernel.
[ 8.182665] arducam_64mp 0-001a: failed to read chip id 682, with error -5
[ 8.184122] arducam_64mp: probe of 0-001a failed with error -5
[ 8.197400] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 8.198083] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
[email protected]:~ $ raspistill
ERROR: the system should be configured for the legacy camera stack
[email protected]:~ $ raspi-still
-bash: raspi-still: command not found
[email protected]:~ $ ls /dev/video*
/dev/video0 /dev/video10 /dev/video12 /dev/video14 /dev/video16 /dev/video20 /dev/video22
/dev/video1 /dev/video11 /dev/video13 /dev/video15 /dev/video18 /dev/video21 /dev/video23
It only shows one camera detected but when i launch preview I can see preview of all 4 cameras.
libcamera-still -t 0 --viewfinder-width 2312 --viewfinder-height 1736
