How to install jetvariety cameras to kernel32.7.1 -XavierNX 16GB Product ver
    Switch Science (a reseller in Japan)
    Jetvariety camera (B0264)
    Jetson XavierNX 16GB (Product version) on reComputer J202 carrier board
    Quick start - Arducam Wiki
  5. Problems you were having?
    I tried to install the driver using install_full.sh script but I can’t get any /dev/video* device file. The script attached arducam-nvidia-l4t-kernel-t194-4.9.253-tegra-32.7.1-20220316014355_arm64.deb
    following are results of dmesg and some other commands.
    uname -r
    4.9.253-tegra
dmesg | head
[ 0.000000] Linux version 4.9.253-tegra ([email protected]) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Sat Feb 19 08:58:27 PST 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: [email protected]
cat /boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT JetsonIO
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/arducam/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
LABEL JetsonIO
MENU LABEL Custom Header Config:
FDT /boot/arducam/dts/tegra194-p3668-all-p3509-0000-user-custom.dtb
INITRD /boot/initrd
    I tried to install the camera module to Jetson nano 4GB(Developer kit ver.). so, it worked successfully.
  2. What help do you need?
    If you have some ideas to install the device to my NX correctly, please let me know.
Our camera driver is not compatible with the third-party carrier board.
Hi, Dion.
Thank you for your reply.
Please tell me which carrier boards are “official” and you can support them.
