from UCTRONICS -
B0343 -
RPi CM4 -
Please give me a link to correct drivers
After installing this driver. Here is result:
pi@raspberrypi:~ $ arducamstill -t 0
Hardare version: c03140
No match to hardware version!
Error opening device.
arducamVideoInit failed.
Unable to set format: Bad file descriptor (9).
I believe this camera module doesn’t have ISP onboard.
Please check!
Sincerely Azer Babaev
Yes, this camera module doesn’t have an OnBoard ISP, but they use the same driver.
I have tried to install arducam_obisp_camera_driver several times. Result is same:
Something goes wrong.
Kernel: Linux raspberrypi 5.4.79-v7l+
Can you provide dmesg logs, and pictures of the hardware connection?
