distributor
Arducam mini 2mp , Rev.B
cubeIDE ( stm 32F7 board)
online documentation or arduino example
Never worked,First Attempting
SPI, I2C communication connection confirmed.
but No 0xD8 & 0xFF were found when reading the data after the capture command.
Where should I check?
flush_fifo();
clear_fifo_flag();
start_capture();
Starting = false;
HAL_GPIO_TogglePin(GPIOI, GPIO_PIN_8);
if(check_fifo_done())
GrabJpegFrame();
void GrabJpegFrame(){
bool is_header = false;
uint32_t length =0;
uint8_t send=0x00;
uint8_t temp=0, temp_last = 0;
length = Read_FIFO_Length();
if((length >= MAX_FIFO_SIZE) | (length == 0))
return false;
fifo_size = length;
int nCnt = 0;
CS_LOW();
set_fifo_burst();
HAL_SPI_Transmit(&hspi2, (uint8_t*)&send, 1, 10);
HAL_Delay(10);
HAL_SPI_Receive(&hspi2, (uint8_t*)&temp, 1, 10);
HAL_Delay(10);
length–;
while(length–)
temp_last = temp;
//HAL_Delay(10);
//HAL_Delay(10);
if(is_header == true)
send_data[nCnt++] = temp;
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_7);
else if((temp == 0xD8) & (temp_last == 0xFF)){
is_header = true;
send_data[nCnt] = temp_last;
nCnt++;
send_data[nCnt] = temp;
if((temp==0xD9) && (temp_last == 0xFF))
HAL_GPIO_TogglePin(GPIOH, GPIO_PIN_4);
break;
MX_LWIP_Process();
HAL_Delay(10);
CS_HIGH();
clear_fifo_flag();
is_header = false;
return true;
spi and i2c command and datasheet check
I want to check the captured data. I’d like a guide.
