We are collecting remote images using an OV2640 mini plus interfaced to an arduino MKR GSM 1400 board. However we are getting very over exposed images during clear sunny days.
The following is a reasonably good image:
The following is a very over exposed image:
The following is the internal setup for the camera image options:
sunny = 1, cloudy= 0, auto = 1, brightness= -2, contrast= 2 and these are setup via the following code:
#if defined (OV2640_MINI_2MP_PLUS) myCAM.OV2640_set_JPEG_size(OV2640_1600x1200); if (_auto==1) {Serial.println(F("Set Auto"));myCAM.OV2640_set_Light_Mode(Auto);} if (sunny==1) {Serial.println(F("Set Sunny"));myCAM.OV2640_set_Light_Mode(Sunny);} if (cloudy==1) {Serial.println(F("Set to cloudy"));myCAM.OV2640_set_Light_Mode(Cloudy);} if (brightNess==2) {Serial.println(F("Set Bright 2"));myCAM.OV2640_set_Brightness(Brightness2);} if (brightNess==1) {Serial.println(F("Set Bright 1"));myCAM.OV2640_set_Brightness(Brightness1);} if (brightNess==0) {Serial.println(F("Set Bright 0"));myCAM.OV2640_set_Brightness(Brightness0);} if (brightNess==-1) {Serial.println(F("Set Bright -1"));myCAM.OV2640_set_Brightness(Brightness_1);} if (brightNess==-2) {Serial.println(F("Set Bright -2"));myCAM.OV2640_set_Brightness(Brightness_2);} if (contrast==2) {Serial.println(F("Set Con 2"));myCAM.OV2640_set_Contrast(Contrast2);} if (contrast==1) {Serial.println(F("Set Con 1"));myCAM.OV2640_set_Contrast(Contrast1);} if (contrast==0) {Serial.println(F("Set Con 0"));myCAM.OV2640_set_Contrast(Contrast0);} if (contrast==-1) {Serial.println(F("Set Con -1"));myCAM.OV2640_set_Contrast(Contrast_1);} if (contrast==-2) {Serial.println(F("Set Con -2"));myCAM.OV2640_set_Contrast(Contrast_2);}#endif
Is there as way using code to reduce this over exposure of is there a better camera option that could be interfaced to the arduino MKR GSM 1400 board?
Any help is much appreciated.
Cheers.
