Hello Arducam,
I have ordered several OV7251 NoIR camera modules (U6070-1). I have a question here:
Is there a way to fixate the FPS of the camera so it will be fully controllable?
I mean that I want to control the exposure, and the time between the frames better/know the time between the frames.
Thanks for your support.
lvbin
July 9, 2020, 6:27pm
2
Arducam release arducam_set_control(camera_instance, V4L2_CID_EXPOSURE,value) API for user to control the exposure.
Is there exposure control in python?
<p>Can I control the FPS?</p><p>If I want 20 FPS, is there a hardware way to get it? (Not by frame dropping at the software level)</p>
lvbin
July 12, 2020, 6:34pm
5
Hello, About the exposure control, you can refer to our demo https://github.com/ArduCAM/MIPI_Camera/blob/master/RPI/python/preview.py
You can try to reduce the exposure time to increase the frame speed. Arducam has not provide frame speed control API.
Thank you.
If FPS cannot be controlled, is there a good way to set the Exposure (Not in RPI), in mili seconds without a formula?
Thanks
lvbin
August 4, 2020, 8:06pm
7
At present we have not a whole formula to calculate the exact the exposure time. This task need the sensor local factory’s support.
This API arducam_set_control(camera_instance, V4L2_CID_EXPOSURE,value) just set the number of the line.
