Uctronics -
Camera Module SKU: B0279 (IMX477 for Jetson Nano), Lens SKU: LK004 (Pack of 5 lenses, fixed focus) -
Jetson Nano Development Board B01 (4GB RAM) -
Driver Installation. I am using the driver provided by Arducam -
I would like to change the frame rate between 2-60 fps for 1920x1080 resolution. -
Tried to pass a different frame rate argument, like in the example below I use30
gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1" ! nvvidconv ! nvoverlaysink
After running the command the console ouputs that the frame rate is 59.999999 i.e. 60 fps:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59.999999
- What help do you need?
I would like to set a custom frame rate between 2-60 fps. I understand that the driver right now only supports 3 modes:
Mode 0: GST_ARGUS: 4032 x 3040 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
Mode 1: GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
Mode 2: GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
However can the Arducam team modify the driver so that it has user defined frame rate?
