UCTRONICS
B0240
RPi 4B
Online forums, etc.
Never worked?
As noted, purchased a B0240 12MP camera w/ lens kit from UCTRONICS. Using an RPi 4B w/ latest version from raspberrypi.org (Buster 03-04-2021) and raspistill using (among other iterations of the command):
raspistill -md 3 -q 100 -k -o hires.jpg... I am only able to obtain a .jpg that is 5.4MB in size. All iterations of the command produce the same result. With verbose option, the following is obtained (seemingly confirming the board and sensor size is correctly detected):
"raspistill" Camera App (commit 4a0a19b88b43 Tainted) Camera Name imx477 Width 4056, Height 3040, filename hires.jpg Using camera 0, sensor mode 3GPS output Disabled
Quality 100, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Time delay 0, Timelapse 0
Link to latest frame enabled no
Full resolution preview No
Capture method : Capture on keypressPreview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode ‘auto’, AWB Mode ‘auto’, Image Effect ‘none’
Flicker Avoid Mode ‘off’
Metering Mode ‘average’, Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera preview port to video render.
Connecting camera stills port to encoder input port
Press Enter to capture, X then ENTER to exit
I would expect an image of a much greater size.
Should I be using different software? Settings?
Thanks in advance,
Jeff
see message
