Hi arducam support team,
I have B0348 camera which supports 120 fps, but in my case I am not getting more than 40 fps.
I am using with raspberry pi 3b+ @ 1 gb ram.
My system detail information
[email protected]:~ $ uname -a
Linux raspberrypi 5.15.76-v7+ #1597 SMP Fri Nov 4 12:13:17 GMT 2022 armv7l GNU/Linux
[email protected]:~ $ cat /etc/os-release
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
[email protected]:~ $ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=0
dtoverlay=arducam-pivariety
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
[email protected]:~ $ dmesg | grep "arducam"
[ 13.139563] arducam-pivariety 10-000c: firmware version: 0x10002
[ 13.481058] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
[email protected]:~ $ libcamera-vid --list-cameras
Available cameras
0 : arducam-pivariety [1600x1300] (/base/soc/i2c0mux/[email protected]/[email protected])
Modes: 'SBGGR10_CSI2P' : 1280x720 [120.11 fps - (0, 0)/1280x720 crop]
1600x1080 [80.02 fps - (0, 0)/1600x1080 crop]
1600x1300 [60.04 fps - (0, 0)/1600x1300 crop]
'SBGGR8' : 1280x720 [120.11 fps - (0, 0)/1280x720 crop]
Please guide me.
Thanks
