I bought one Camarray module with four imx219 cameras (B0396) and I replaced the imx219 cameras with an fisheye imx219 camera (B0286), that has a fov of 220°.
I tested it with a Jetson Nano, and it worked fine (after some restartings).
I tested raspistill and I got an error (it couldn’t create the camera).
Now I want to acess the camera via Raspberry Pi.
How can I get the stream of the cameras? Do I need to install some program or something like that (I thought it is native)?
Best regards,
Konrad
raspistill -o ~/Pictures/first_image.jpg ->
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: Failed to run camera app. Please check for firmware updates
I also checked the ribbon cables, GPU memory, Raspberry Pi and I tested the official imx219 camera, that is working fine, but I couldn’t solve the problem.
Best regards,
Konrad
Thank you for your reply. I added it and now I only get the error: “ERROR: the system should be configured for the legacy camera stack”. Do you know what that means and how I can solve it?
Many thanks in advance Konrad
Do you use the Pi 3 or Pi zero? If so, please follow the steps below:
command: sudo raspi-config
3. Interface Options
->1. Legacy camera
->disable
Then add camera_auto_detect=0 under the [all] at the bottom like my previous reply.
Sorry, that I didn’t answer because I didn’t see that you answered. I don’t have the problem anymore because my Jetson Nano arrived, and it runs without problems. But should I close this topic, or should I try to solve the problem? Because of your question: I installed 32 bit Bullseye with the RPi imager.
Best regards, Konrad
